Thermalright XP-120 or XP-90
holycpu
Thermalright XP-120 or XP-90, I have do a google search and i have new question.
All I can find is a copper-aluminum thing....where is the fan? How can it combine with the fan? Will the instruction guide show u how to connect the fan with this heat-sink?
I went to the offical website and found no image about fan + this heatsink combine.
Anyone who own this heatsink, can you give some info please?
Thank You
You can just buy a fan and put on it. XP-120 uses a 120mm size fan and XP-90 uses a 92 and i think 80mm fan. Both come with proper mounting tools for the fan, and should have instructions.
c0rrupt got it right, you buy your own fan and slap it on there, its just some wire clips that attach to the heatsink and clip on the edge of the fans to hold the fan on, all comes with the heatsink. If you go XP-120 make sure it fits on your motherboard, the thing is fricken huge.
There's also another XP in the mix as well....the XP-90C, an all-copper XP-90. I'm not sure if it out performs the XP-120, but I'd like to see them head-to-head. I have 1.65v on my 3400+ CG Claw right now and have been running Prime95 since last night and it's at 48-49C, and we're about 10 hours into it. I personally love my XP-120, but I'd still like to see an XP-90C in action :D
The problem with the xp-90C is that is its freakin heavy. You have to put a beefier support bracket behind the mobo i think.
XP-120 and Panasonic Panaflo 120mm x 38mm FTW.
4000+ 32c Idle @ 2.7GHZ
The XP-90 are coming with a crap fan now. I have both, and honestly I have to say the XP-90 is great.
i have an xp90 with a tornado on it, and according to abit's eq(notriously sucky!) when my A64 2800+ is oc'd to 2.45GHZ with 1.65v it doesnt get over 51ºC, but according to an article i read, abit boards can over read up to like 13ºC
and for 25 bucks, from svc with the code xp90, its not worth the extra 25 for an xp120 or the xp90-c. with your savings buy a nice fan, possibly delta tri-blade fan. they are quiet and push alot of air.
It's only 1-2deg cooler than the normal XP-90 and still a few degrees under the XP-120. There was a review on the front page a couple days ago that compared the three.
Between the price, weight, and performance - there is no reason to buy an XP-90C.
Here is a review comparing the performances of XP-90, 90C, and 120.
