Thermalright HR-05 SLI
Docmhz
I have the HR-05 SLI coming for my DFI Ultra-D board and am wondering if I need to put a fan on it or not? If so, what fan should I get for it? Which way should the fan be oriented?
The fins will be right above an 8800 GTS and I'm worried that it will pick up some of the heat from that as well as the chipset.
Thanks!
i just picked this up for my HTPC and without a fan it keeps my northbridge very cool (much cooler than the stock POS HS).. and this sitting right next to a passive HR-01..
anyways if you find that it is sitting right next to your video card and want, i found it is pretty easy to re-orient this HS.. i have mine going on a diag to try and get it as far away from both the video card and the CPU.. my temps for my 6150 (which is an integrated NB/Video card) sit right around 29C and under load get upto about 36C, all passive with only an intake, exhause case fan..
i have to say that the thermalright HR series is by far some of the best stuff i've bought for my PC.. so far i'm rnning the HR01 (CPU) , HR05 (North/Nforce) and the HR03 (X1900XTX)..
Thanks for the reply, I'm looking forward to seeing what it can do. I think I understand how you are telling me to orient it down and away from the card, I'll see if I can make it do that.
I do have a 120mm fan on the side of the case that blows directly on the video card and should provide some flow across the HR-05. If I decide to put a fan on it, should I orient the fan to blow down onto the card or to exhaust away from it?
Here is a picture to give you an idea of how i did mine..
keep in mind this was on a non-SLI board, and space was a big issue (but i wanted this over the HR05 non SLI version).. with care i was able to position the heatsink in the position i wanted..
Here it is assembled
I agree.... especially the HR-03, it looks so bling.... I have a thermalright family too lol, when my rig is on air I have an Ultra 120.... I bought 2 of these hr05 cos my nb hsf is connected to the sb so I have to replace both.... My mobo looked too cluttered so I ended up returning one and Im gonna use a Zalman HS instead for the SB...... I have a 120mm fan pointing towards the hr05 and rams, also I didnt use the clips but instead i used screws for better contact....
