Mar 8, 2004 #1 T TITAN24 n00b Joined Jan 27, 2004 Messages 44 I just got my p4 3.0 in the mail and it came with Artic Alumina Artic Silver. I dont know much about thermal compound and am wondering if this is a good kind to use or should i go out and get another kind?
Mar 8, 2004 #2 J jamestime88 [H]ard|Gawd Joined Dec 10, 2003 Messages 1,209 its a good compound. i would just use it rather than go out and buy some new stuff. but if you decide to buy some AS5, u may get 1 or 2 degree difference.
Mar 8, 2004 #3 F FrothyByte [H]ard|Gawd Joined Jun 24, 2001 Messages 1,672 It will do. If you do any serious OCing then you may want to make the investment in a different compound.
Mar 8, 2004 #4 O OldMX 2[H]4U Joined Mar 17, 2002 Messages 3,532 Just use a small drop of ASAA on cpu, then install heatsink, let the pressure of clips make the spread work, you´ll be OK Good Luck OldMX
Mar 8, 2004 #5 O OPUS1 [H]ard|Gawd Joined Apr 25, 2003 Messages 1,766 Ive tried AS3,5 and Ceramique on my CPU and GPU. At best 2-3c temp differance. I go with the big C due to non conductive qualities.
Mar 8, 2004 #6 M Mister Natural 2[H]4U Joined Oct 10, 2002 Messages 3,441 Instructions on how to use.
