Background: I have 2x Tivo HD's that are coming up & need a renewal of the tivo sub, that I really dont want to pay for. When I bought them I knew that as soon as a cablecard tuner hit the market I would be dropping them & moving to a htpc & well that has happened so its time to part ways. The biggest hurdle will be convincing the boss (my wife that is) that we need to upgrade. So this needs to basically have "just enough" hardware to do whats needed. I will worry about upgrading later.
HTPC using Ceton InfiniTV 4 CableCard tuner & needs to playback BlueRay
No Budget as this thread is to combine the colelctive Genius's of the GenHard forum to see what I need to convince my wife I "have" to get
3) Where do you live?
Idaho. All parts will be net ordered
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
Case, CPU, Mobo, hard drive, MCE compatible remote, PSU, BR player & Whatever else I am forgetting
None
6) Will you be overclocking?
Negative
1080p Plasma
As soon as the wife is convinced, But will have to be done by mid sept as thats when my Current Tivo Subs expire
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
If using onboard video then I need HDMI out w/ audio support
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Negative
Biggest concerns are Price, Noise, & Power in that order.
Edit: also please include the cost of any software that will be needed like the BR playback software if the drive does not include it
None
Negative
1080p Plasma
Negative
