The Witcher - Budget Build
Zeyne
I am looking to build my momma a computer. This computer will only be used to surf the net, play music, play Fable: The Lost Chapters, and The Witcher.
Basically I am looking to have a budget build of $200-$300 dollars (after T&S) that can run the Witcher. The minimum requirements for The Witcher are:
Minimum requirements:
Microsoft® Windows® XP Service Pack 2, Vista (Operating System must be up to date with the latest fixes)
Intel Pentium 4 2.4GHz or AMD Athlon 64 +2800
1 GB RAM for Microsoft® Windows® XP / 1536 MB for Microsoft® Windows® Vista
128 MB Video RAM or greater with DirectX9 Vertex Shader/ Pixel Shader 2.0 support (NVIDIA GeForce 6600 or ATI Radeon 9800 or better)
8.5 GB available hard drive space
DirectX 9.0c compliant soundcard, plus speakers or headphones
DVD-Rom
What I have is:
Case
Monitor
Windows
I may be able to come up with a Hard Drive. But I would rather just get a new one :).
I also have a used x1550 that I can throw in there. If there is a cheap card that will fit in the budget, mention it :) http://www.newegg.com/Product/Product.aspx?Item=N82E16814102079R
Thanks for all the help!
You're going to be best off buying a computer from the Dell outlet. Buying individual parts, no matter how cheap, will add up too fast. For super-cheap, you can't beat a refurb/scratch&dent Dell.
When you say "play" do you mean on like, full settings on a decent resolution, or minimum settings...
I have a AMD 4400+ X2, 2 Gigs of 2-2-2-5 DDR RAM, an 8800GTX and a 74GB Raptor drive (granted this is basically 3 year old hardware)...and medium settings is kind of choppy.
At the very least you are going to need a ~$170 video card like a Radeon 4850 to handle the Witcher. Add RAM, CPU, Mobo, PSU (even all of this low end) you'll be looking at closer to $400.
AMD Athlon X2 4050E CPU - $59
Gigabyte GA-MA74GM-S2 AMD 740G mATX AMD Motherboard - $60
Super Talent T800UX2GC5 2 x 1GB DDR2 800 RAM - $41
eVGA 512-P3-N954-TR GeForce 9500 GT 512MB PCI-E Video Card - $70
Antec Earthwatts EA380 380W PSU - $30
Western Digital WD1600AAJS 160GB 7200 RPM SATA 3.0Gb/s Hard Drive - $42
Total: $ 302 plus tax and shipping
The above build will at least run the game at minimum settings. Can't tell you what resolution it will be able to do it at but still, for a $300 budget, this is probably the best you can get.
If you can spare a hard drive, you can use the extra cash to get twice the performance:
Foxconn 9600GT-512F GeForce 9600 GT 512MB PCI-E Video Card - $100
4850 If you can spare 150$ on a video card would really help I think.
