Alright, lately I've been battling bluescreens when the computer sits idle... and also I've had bluescreens during games, and orthos failing almost immediately when it use to run forever...
I thought it was RAM, but ran multiple memtest's.. some for over 24hrs and nary an error was found, so I concluded it couldn't be the sticks. The errors revolved around memory however, and I thought it may be a bad board, or voltage problems to the MCH/DIMM... I went through the circuits manually on my motherboard with a multimeter and found several circuits low on voltage for the DIMM's... I did several other tests and concluded it was my PSU. I replaced the PSU and I had a noticable improvement.. orthos ran for much longer, but still error'ed out.
The bluescreens started to come back the next day, and again started corrupting my harddrives (lost 4 vista installs). Aggravated, I went to fry's and purchased another E6600 B2 batch and brought it back. when I went to boot the system it began giving me a ram error beep and failing to post or even power the video... I removed one of the sticks and it powered up into windows just fine... What the fuck is going on? Ever had a ram stick that is as stealthy erroneous as this?
I'm still troubleshooting too, btw... but all tests show these sticks are perfectly fine?
