BillR
Born Again Cynic
- Feb 17, 2002
Of late in this forum and others I have noticed a commonality in many threads with regards to:
I turned on my computer only to have the fans start for a moment then stop.
I turned on my computer and it wants to double or triple boot but still wont run.
My Power supply must be bad because See all of the above.
The issue is most common to current Intel based boards paired with multi rail power supplies.
This is going to sound funny however I have had it work a number of times now with non boot situations, double boot situations etc. The best part, its free and simple.
Turn off your computer, then power down the power supply using either the switch or simply unplugging it. Wait a moment or two and turn the PSU back on but dont attempt to start the computer. Once you see the lights on the motherboard are on (showing your PSU is working) unplug the 24 pin motherboard connector from the board. (Yes, with the PSU still powered on). After another moment or two plug the 24 pin connector back in. After that then try to power up your computer.
The problem seems to exist primarily with Intel chipsets and multi rail PSUs. Take note that virtually all the big players in the PSU business have been busy switching back to single 12v buss PSUs.
This problem can crop up randomly, after BIOS flash or reset or even a momentary loss of power to the computer.
To date Ive done two Abit and one Msi board with 100% success. I stand corrected I did it to mine which makes 4 successes with boards that were already to be RMAd.
Like I said, free and easy, if it works for you life is good.
