Current decent buys (including 3rd party firmware support):
Budget (no dual band):
http://www.google.com/products/cata...a=X&ei=FEovUJ3kGoGp4gTh8YDACw&ved=0CGEQ8wIwAA
Mid-range (dual band)
http://www.google.com/products/cata...a=X&ei=vEkvUOP1Bav74QTHuoHYAw&ved=0CFkQ8wIwAA
Premium (dual band and more memory)
http://www.newegg.com/Product/Produ...eless+Routers-_-Buffalo+Technology-_-33162048
//Danne
If you want to go 3rd party firmware the Atheros platform is the best choice overall, this is also what Ubiquiti use in many of their products. Looking at the hardware itself...
Buffalo WZR-HP-G450H
CPU: Atheros AR7242 400Mhz
RAM / Flash: 64Mb / 32Mb
TP-LINK TL-WDR4300
CPU: Atheros AR9344 560MHz
RAM / Flash: 128Mb / 8Mb
Linksys E4200
CPU: Broadcom BCM4718 480Mhz
RAM / Flash: 64Mb / 16Mb
While the TP-Link does have more memory and faster CPU it lacks flash memory which might hold you back if you want to run simple services on it. It'll probably be faster than the Buffalo overall. Compared to the Linksys I'd say that the Buffalo and Linksys will most likely perform very similar and the TL-WDR4300 better than both in raw performance. Since Broadcom doesn't have open source drivers you need to rely on binary blobs which usually are rarely updated and very limiting when it comes to 3rd party firmwares. I know DD-WRT likes cludge like that more than the OpenWRT community so it might work out if you want to run DD-WRT, I would personally take OpenWRT over DD-WRT any day. Also keep in mind that 3rd party firmware isn't equal to better performance even if that's the case most of the time.
//Danne
Hi all, first post here, so, thanks for having me ^_^ I'm looking to setup a training network to coincide with CCNA and Computer Sc BSc courses I'll be starting shortly. Here's the rig I'll want setup by the new year.
HTTP LAMP Server
NAS w/ FreeNAS
Workstation for VMWare and web dev (this's already built)
I'll most likely be getting a Cisco SG300-20 to cater for expansion but I was wondering if anyone can recommend the Cisco RV180W?
TP-LINK TL-WDR4300
Linksys E4200
//Danne
Wired would be gigabit speeds, wireless I'd say about 100mbit (that's what my old Planex-router does and Intel 6200 WLAN-card) and it's 2 generations older than Buffalo and TP-Link (newer generations have better radio). If you only need a router you'll probably be better off going for the TP-Link. I have nothing to complain about regarding wireless stability, works really good for days without reconnecting but that might highly depend on how much interference you'll have.
//Danne
Looking to start up a local LAN party. Location I want to use is free and has free wifi. The wifi is a frac T1 and tests out 2-3mb up and 3+ mb down.
My idea is to use a wireless bridge device to grab the signal and then share it out as well as perform standard DHCP etc by plugging into a 10/100/1000 24 port switch. All machines would hard connect into the switch.
Any reccomendations on a router/bridge device that would do what I need it to? I have been told a high end router flashed to DD-WRT might work?
Any ideas?
I think this is a much simpler than requiring everyone to have their on WIFI card in their machine.....
//Danne
I'm not sure what an electrical converter would be or do in this case? I am only familiar with the term in regard to socket variance from other countries, an adapter of sorts.
He might be talking about powerline ethernet. They use the wiring inside your house to connect systems. I myself hae never messed with them.
Just came across this, might helps those looking for a new router...AVS: 5 Best Wireless Routers For Your Money
Though going by some of their choices I think they might be a tad too consumer and not enthusiast like [H] seems to be![]()
The 3700v2 is superior to v1 in all ways but they're getting old by now
//Danne
I have a new RT-AC66R and it is FAR from stable. It's a mess in fact.
UPnP doesn't work.
SAMBA doesn't work right.
DLNA doesn't work.
Port forwarding doesn't work.
And the firmware released today fixed NONE of these issues.
It's going back. I love the performance, but I've had enough. I'm hoping the Dark Knight has all these issues (or whatever issues it may have had) worked out by now.
Am I good to go on one of these?
You might want to consider a 3rd party firmware-compatible (Atheros platforms works best) router if you want to go with a 3G-modem since you'll be able to get updated drivers without too much hassle.
//Danne
