The onboard NIC vs a card
PlaidJello
If I understand correctly, a benefit to the nforce3 250gb is the NIC isn't on the PCI bus. However, if we're talking about a VIA or other chipset is there any benefit to running an add-in nic vs onboard? Or since the nic goes in the PCI slot, is it basiclly going through the same channels as the onboard and therefore about the same?
As long as your onboard LAN isn't something crappy like a Realtek, then it doesn't really matter. If you do go for a PCI NIC, I'd suggest Intel.
depends on if you're talking about a software or hardware nic. An intel server/workstation nic is gonna kick a software nic's ass -- that includes PCI and integrated nics.
Intel and 3com are the two brands I like to stick with. But make sure they're hardware nics -- and not just software nics. Kinda like the difference between a software modem (winmodem) and a hardware modem... A hardware nic will do all it's processing on the card... A software nic utilizes the cpu.
My motherboard has an integrated NIC, per the nForce2 Ultra 400. However, I seriously dislike it. For one, it eats too many cpu cycles for my liking (3-5%). You may see this as asinine with the current cpu speeds, and maybe it is, but I dislike it. :) I popped a dedicated Realtek NIC in and cpu usage is 0% 99% of the time, with *maybe* a spike to 1% off and on.
^ I see no prolems? Transfers are as fast as always, and cpu useage is low.
realtek has usually give me about 70Mbps throughput -- which is acceptable for any home use or LAN parties.
But if you're gonna put the money, time, and effort into making the rest of your system [H], then don't skip on the NIC... Don't we pride ourselves on having every aspect of our systems being excessive? yes... yes we do :p
