The Most Badass 120mm Fan? Help me find it?
Zarathustra[H]
Extremely [H]
Hey all,
So I am planning on using a 120mm fan and a PC PWM fan controller for a non-computer project.
Because of this I am looking for a 120mm fan that can move as much air as possible.
Must be insane to the point where no one in their right mind would put it in their PC, and must be controllable via 4 wire/PWM.
I got one of these, it was powerful, but I feel I need more.
Appreciate any suggestions!
Look closer ;)
Its got 3 different profiles to choose from.
Hybrid 500-1200rpm, performance 2000rpm and advanced 3000rpm.
Look closer ;)
Still only 101cfm at max whereas the op posted one is 120cfm stating he wants to move more air...
San Ace 9CR1212P0G03
7.2A @ 12VDC (86.4W)
6200RPM
300CFM
70dBA
Best I could find. Of course, at 76mm wide, you're basically looking at the width of two fans. Might be worth comparing it to a pair of stacked Deltas if you've got 'em.
6200RPM
300CFM
70dBA
76mm is 3 standard case fans thick, not 2.
That fan is awesome. I use an NF-F12 iPPC 3k as an exhaust it works just as good as the 120x38 I had there before.. well maybe a bit better because I let it rev. The iPPC is much louder though. I originally had a big-n-little setup on my heatsink.. but the NF-A14 iPPC is good enough for the girls I fu.. I forgot I'm married so scratch that. I was using a 120x38 24v NMB running at 12v previously as an exhaust. I've never owned a Delta, but I wouldn't mind picking up some 120x25 screamers or maybe some of the same but in 140mm. I have enough 120x38s to stuff every orifice of my Meshify C. I used to swear by them.
Can you imagine sticking your dick into that San Ace lol. What a horror movie.
The promo they put on yt is pretty ridiculous. I mean, my 8" vornado could do the same thing...but it's 8" diameter. lol That San Ace literally screams, would not want it running full blast anywhere near my ears, not even in the same building. XD
48 watts!!
What kinda fan controller would you recommend?
I think this one would work,
Lamptron CF525
Amazon Link
Features:
- Most powerfull controller in the market
- 60w per channel
- Very high quality materials
- 5 completely independant 60w/5A channels
- Other Great Features!
- CNC milled aluminium face-plate
- Sleeved cables
- Black PCB
- No frills, just power
Specifications:
- Dimension: 148.5mm*42.5mm*76mm(5.25" Bay)
- Power Output: Up to 60 watts per channel
- Control Channel: 5 Channels
- Panel Color Available: Black Anodyzed / Silver
- DC Input: +12v (1pcs MOX4.2 5557-2*4p connectors. A.k.a PCI-E GPU 8pin)
- DC Output: 0V- 12V DC
- Connectors: 5 X 2510-3pin connectors / 8pin to 3xMolex adaptor)
- Recommend PSU wattage: 700w or higher. It is imperative that no molex multipliers are used to plug in the 3 molex adaptor suplied.
Lamptron CF525
Amazon Link
Features:
- 60w per channel
- Sleeved cables
- Black PCB
Specifications:
No frills but has sleeved cables lol
I do always love all the Lamptron gear I’ve bought.
