I ordered two new 1TB WD Caviar Black's to replace my current two-year-old 320GB Seagates. I'm excited for the performance increase but more so want to make sure I get the most performance out of these new harddrives. I've been short-stroking my hard drives for awhile, but was wondering if anyone had ever mathematically figured out the optimum configuration/percentages/set-ups for short-stroking. Googling has turned up nothing.
If not, I imagine it would be relatively simple to do some quick calculus to the figure out what would be optimal. Basically, one would figure out the rate of speed penalty as one moves from the outer edge of the platter to the innermost edge. Next, one would figure out how much space one gains moving from the outer edge of the platter into the innermost edge. Analyze the curves and you have your answer of how large of a partition to create. However, it might not be so simple, and I don't have the background in HDD technology to verify my hypothesis. First, is HDD space directly proportional to area across the platter? Or are there more dense zones and less dense zones? Also, is there anyway to make sure that you're writing to the outer edge of the disk with your first partition, or does Windows do that automatically, every time? Is there a program where you can actually "see" where your partitions physically are on an HDD?
If my hypothesis is correct, I want to write up some quick equations based on proportionality, and then one can easily multiply by platter density and number of platters to figure out the final "optimal" partition size for maximum speed (or where and how much give and take you can have).
Thanks
Thanks
