Okay, need help with another build. This time for my wife's parents. Here's the details:
Web-browsing, email, general office functions, viewing pictures of the grandkids
Like to keep it as cheap as possible but under $600 for sure.
3) Where do you live?
Chicago area
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything from the case in
Just a monitor. I think theirs is 19" but no real worries with GPU ability as gaming is definitely not gonna happen on this machine.
6) Will you be overclocking?
Nope
See #5
Within a week or two
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Nothing special. Would like to keep case size reasonable though.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? 32bit or 64bit?
Will need to purchase Win 7
I did some looking at another "parent build" in this thread and the build seems to fit their needs. Just wasn't sure if there were some more recent deals I should consider. I figure I could save a few bucks on the memory and DVD drive. Also need suggestions on an inexpensive but decent case.
$100 - AMD Athlon II X4 630 CPU
$67 - Biostar A785G3 AMD 785G mATX AMD Motherboard
$105 - A-Data AD3U1333B2G9-DRH 2 x 2GB DDR3 1333 RAM
$56 - Western Digital WD5000AAKS 500GB 7200RPM SATA 3.0Gb/s Hard Drive
$27 - LG GH22NS50 DVD Burner
$55 - Corsair 400CX 400W PSU
$100 - Windows 7 Home Premium 64-bit
Total $495 + the case
Chicago area
Nope
See #5
