Archaea
- Oct 19, 2004
So my understanding is I can fit the
SEASONIC PS SS-400H1U 400w PSU $100
Sparkle 9800GT Low-Pro $115
And add some fans externally, it would all fit?
That PSU should fit...but you'd be the first to try the 400watt highly rated seasonic PSU so I am all ears to hear about your exp. How loud it is was my concern and the reason I opted against it. Given that I was able to modify and quiet down the sparkle 270 watt PSU to near silent I prolly could have done the same thing to the seasonic --- as can you.
You'll almost surely need a six pin pci-e adapter for the 9800gt.
You will need a sata power adapter for each: the hard-drive and the cd-rom. If there is only a single line with two sata adapters on that power supply-- the connectors will not likely reach the cd-rom and hard-drive since they mounted at 90* of each other. Thus you'll likley need a molex to sata adapter.
