Dan
- May 23, 2012
IBM t42 like 3773 or something. Thanks for looking though! it has 2x 512 now
i will check when i get home. i may have one, might be IDE though. If i do just cover shipping.
I have a modified cooler master elite 360 ATX case that's taking up space in my garage. Cover actual shipping and its yours. I removed the 5.25" bays to fit a full size psu.
EXPIRES THURSDAY JANUARY 31 at 5:00 PM PST.
After that I will throw it in the trash
Where do u put the power supply in this case?
Hey, folks... you know how much I've been giving away lately it's hard to miss.
Here's two things I need --
(1) a VGA extension cable where the male end (plugs into the mobo) is at a right angle to the cable.
(2) a PS/2 extension cable with the same feature.
I can probably make the PS/2 cable if I have to, but I'd rather not if I can avoid the ghetto mods thread. eBay came up with blank stares when I searched for one there -- and the VGA cables that I saw were $11+. No thanks.
As a note, this is for a small computer build, so the shorter the cable the better.
EDIT: made the PS/2 cable, still NEED the VGA one...
Does anybody have an old SATA HDD that they don't need at all. Size really doesn't matter just want 80GB or more. Really need one as i thought the motherboard i got supported IDE but it doesn't so i have no HDD that i can use
now add the words "right angle" to that search and see what you get key phrase in my post was "with the same feature" meaning right angle at input.
No worries... anyone got the right-angle VGA cable somewhere?
TRRS iProduct compatible Microphones x2 (Didn't work with my HTC Phone, so likely Apple iProduct only)
http://ergh.org/yardsale/minimic.jpg
My P67A-G43 has served me well for the year and a half I've owned it.I have never had an MSI motherboard that did not give me issues. (I am not speaking of any other MSI products not including laptops)
Okay, was going to try and sell this, but due to members like Starhawk I figured it was worth just sticking it in here for free!
I have a C2D P8400 Intel mobile chip. Runs at 2.267 with 3mb L2 cache. It is the Socket P (479) at 25 watts.
http://www.cpu-world.com/CPUs/Core_2/Intel-Core 2 Duo Mobile P8400 AV80577SH0513M.html
I recently upgraded my old Gateway P7811-FX to a T9400 and have this P8400 left that I know I'll never do anything with LOL.
So if someone is in need of a good Core 2 Duo mobile chip give me a holler and I'll be glad to ship it along for the cost of shipping.
Highwind, the symptoms you specify sound like a dead power supply, not a dead mobo -- I assume you tested for that?
EDIT: TBH, if it was mATX I'd take it. I don't have a full ATX case!
Until February 28, 2013, you’re eligible to upgrade to Windows 8 Pro for just $14.99*. This is the best upgrade price and an amazing opportunity.
Run the Windows 8 Upgrade Assistant and follow the steps to purchase the upgrade.
