Long shot but I thought someone might have them floating around
My Hannspree LCD monitor just died and I happen to like it.. it blinks on and off for about and hour and then might come on to stay but usually not
Opened it up and found two bulging and leaking caps so I think that is the problem..
The caps are:
Samxon
680uf 25v
105C
They also have the marking GK(M) and Y4C on them
They're like a pine green in color
I did a quick search online and really couldn't find those exact ones and when I did it was like a 20 pack or a 50 pack.. I only need two or maybe three if I mess up..
Oh and I'd be willing to trade the caps for one of the games in the list in my FS thread: http://hardforum.com/showthread.php?t=1644073
The caps are:
Samxon
680uf 25v
105C
The caps are:
Samxon
680uf 25v
105C
404, I'm surprised you don't have anyyou and jojo69 would be on my PM-instantly list for that sort of thing (Mohonri would be third in line, mostly because I don't know him as well). I know that both of you (and Mohonri as well) are good with electronics.
EDIT: Mouser has 'em -- dracos, if you can post (mm, please!) the diameter and height of the busted caps, as well as the distance center-to-center between the leads (down the middle of one to down the middle of the other, if you know what I mean), I can find you matches there.
Also, if you don't know -- Mouser Electronics is a BIG electronics site, sort of what Radio Shack would want to be if it still was what it used to be (a hobbyist electronics parts store) only Mouser also sells to The Big Guys as well. They sell EVERYTHING. You name it, they got it, I mean it. You know the Weird Al song, "Hardware Store"? You remember how he rattles off all the stuff you can buy? Yeah, that, only it's electronics instead of tools and hardware. They also have a really convenient shipping option -- flat $5 to a residential address if it's little enough to fit in a FedEx ReadyPost box(Might be UPS SurePost; don't remember.) Very handy. www.mouser.com -- go there and watch li'l ol' Radio Shack piss its pants because it ain't half o' nothin' in comparison.
I was just ribbin' ya, dude, don't take it personally!
I agree re: PCunicorn's post -- if they fit, they'll do fine and they're a GREAT price.
The caps are:
Samxon
680uf 25v
105C
Does anyone have any good 92mm fans layin around? Would like to have a slim ,But most want to hang onto those![]()
dracos, you'll want to check the lead spacing (per my edited post, above) before you spring for those eBay caps. They'll be cheaper than what I was suggesting, tho, when you factor in Mouser's shipping.
Would anyone have a matx or itx 775 that supports E8400 or Q6600 using ddr2 memory? I currently have a Zotac NF630i that doesn't support either one of the processors.
Also this board has three budging caps but will still work. A freebie to anyone for the cost of mailing.
edit: it supports the e8400 but its not booting up. hsf is just powering up. might need a bios update but the cpu I had, e6420, I give away to another member. think I prefer to just get another board that will support both e8400 and q6600.
Does anyone have a spare 939/AM2/A2+/AM3/775 mobo & processor they no longer need ?
Does anyone have a PCI Network card (preferably Intel) that I could have? My desktop only has one LAN port and I need another so that I can do some split subnet work. I can paypal shipping costs right away.
I have a couple...but not Intel. I think one is a 3Com, and the other is a Netgear FA311
I'll have to look when I get home, but I believe it is this one.
Shot in the dark, but looking for a XB360 power brick.
Thanks a lot![]()
Free for the cost of shipping:
6-8 SATA cables
several power cords
2 USB a-B cables
1 molex to 2x sata connector
Gets tossed in ~12 hours
Had a couple of these, I'll check the chipset and let you know if I still have them what they are (not used them in so long I'm not sure I still have them)
Does anyone know where I could get a trial code for Xbox Live Gold? I want to try some of the media streaming apps without handing over my credit card info first.
Free for the cost of shipping. Expect that to be ~$3-4. Will be gone in 24 hours.
Sealed Windows 98 OEM SE. I will include something hardware with it so the EULA won't be violated.
