It's tesla...
I wonder if a Geforce version of GK110 will be released?
You aren't doing so great as an Nvidia fanboy, Prime.
If AMD can not bring anything at least 30% faster than the GK104 and a card that can beat the 690, we may never see the GK110 Geforce. Maxwell (the next generation after Kelper) was slated for a 2013 release so they may just skip ahead.
He was just posting some information. Why you gotta bring up fanboyism when no one else was?
You are really quoting the same graphic that has Kepler in 2011?
removed.
This product is based upon new GK110 silicon, a 7.1 billion transistor manufactured using 28nm process node. According to Jen-Hsun Huang, this is the largest number of transistors on a single piece of silicon Xilinx has the second place with a FPGA chip with a bit over six billion transistors. Third one is a GPU from AMD, the 4.31 billion transistor monster, and then we get back to GK104 with 3.1 billion transistors. Top 5 are rounded with a 10-cor Intel Westmere processor, a 2.6 billion transistor chip manufactured in 32nm technology.
GK110 i.e. Tesla K20 brings over 1.5TFLOPS of double-precision FP performance, i.e. 3x more than Tesla C2075 with its 515 GFLOPS. The GK110 GPU brings an unannounced number of cores, 384-bit memory interface and an undefined amount of onboard memory. The memory combinations possible are 6GB, 12GB or 24GB. Jen-Hsun mentioned that the amount of memory depends on the DRAM industry. We expect to see the 12GB version, though.
GK110 hasn't arrived, the Tesla K10 is in fact GK104.
The GK110 based Tesla K20 is due at the end of this year. So it hasn't arrived![]()
it will but as a GTX 700 series near the end of this year. probably around the same time AMD plans on releasing their 8k series aka GCN v2.0.
It will be interesting to see if Nvidia has finally hit the wall on transitors. I understand that 22nm is relatively new, has many problems and is steadily improving but I wonder if Nvidia bit off a bit more then they could chew with the GK110/100 design?
It looks like AMD didn't even want to attempt this.
who knows.. it could of been the reason GK110 ran into so many problems. but my guess is most of the problems they ran into had to do with heat and power usage given the size of the actual gpu in comparison to GK104.
It will be interesting to see if Nvidia has finally hit the wall on transitors. I understand that 22nm is relatively new, .
Small Nitpick. 28nm
Good post though. It may be right on track with what went down.
its still GK110.GK110 Arrives? Nope, just Tesla
its still GK110.
Finally a real 50-100% upgrade instead of rip off place holder we were given for $500.
I guess my GTX 670 will be worth what it should be $250 any day now.
The US government plans to install nearly 19,000 of Nvidia's new GPUs into its Titan supercomputer later this year. Chip maker Nvidia has revealed details of a new graphics processing unit (GPU) which it says will create the world's most powerful computer. Thousands of the firm's Tesla K20 modules will be fitted to an existing supercomputer at Oak Ridge National Laboratory in Tennessee, US. Nvidia says the machine will run nearly eight times faster than at present, carrying out up to 25,000 trillion floating point operations per second. Nvidia says the addition of its chips should allow Oak Ridge's Titan system to leapfrog from the world's third fastest supercomputer to the top spot.
But the extra speed comes at a cost. The upgrade is expected to involve the addition of almost 19,000 Tesla K20s. Each is set to have a list price of between $1,500 and $2,000 (£930-£1,245), although the laboratory will get a discount for buying in bulk. However, the investment will be partly offset by the fact that the machine should burn up less energy.
worskstation cards usually cost way way more than desktop versions. by the time this comes out for desktop it could easily be a $600 card or maybe less. of course that depends on other factors too such as what AMD will have to offer at that time.Nvidia chip aims to power fastest supercomputer
http://www.bbc.co.uk/news/18033970
For those too lazy to read the article..Tesla K20 will be $1,500 - $2,000 so expect the desktop version to be pricey too.
