That clicking sound is perfectly normal. All CRTs that I've ever encountered do it. Dust isn't a problem with CRTs either, if it was you would hear about people blowing the dust out of their monitors!Lazaryn said:Well in my opinion the monitor is absolutly ugly. It also makes loud clicking noises when changing resolutions which is most noticable when the computer boots which could possibly be because of the many large air holes on the top. I'm guessing that due to the vast amount of these air holes dust will become a larger problem.
The fan support looks good to meLazaryn said:Day six
Not much happened today, I make a hole in the fan support, cut out the template for the side panel window and did some small paint touchups on the case.
