p3sty
- Feb 22, 2006
MY 6950 cant run furmark on stability test at stock think I have a reason to RMA?
It's at stock 6950 speeds I reflashed it back to 6950 speeds because gaming at 6970 speeds wasnt stable at all. Furmark fuzzy donut owns my card is whats happening.
LOL not using case got a antec 900 andd edited my sig. Even when i put the fan in manual at 60% and the temp doesn't rise it locks up.
WELL USING THE +20 POWER SLIDER TO +20 ENABLES ME TO RUN FURMARK. shouldn't I be able to run furmark at stock settings?
Perhaps your unit is not efficient enough to run that card and setup during furmark and the voltage limiter technology (power tune) is causing some kind of instability in the app. It's funny how when you force the card to use max board power it works. It could be possible that you need a power supply with a little more amperage on the +12v rails to run furmark with powertune at 0. It'd be interesting to see how much power is being pulled using a kill-o-watt on your setup while running furmark. If over 425watts then it's over the 85% bronze certification of your unit and performance beyond that point only gets worse.
