The Case For 30fps PC Gaming
HardOCP News
[H] News
Something tells me we're being trolled....or are we?
Top-of-the-line enthusiast gaming PCs are built for raw performance, boasting technical specifications with far more horsepower than the Xbox One and PlayStation 4, opening up a wealth of gameplay options unavailable to console owners. If you fancy gaming at 2.5K, or 4K, at 60fps, 120fps or even higher, the PC is the only format with the flexibility and scalability to deliver. But that's not to say that the console-standard 30fps isn't a good fit for certain hardware specs, or specific titles.
Yup, some games just look better in lower resolution and with capped lower framerates. Like... well you see there's, hmmm, but... well the view angles, trajectory, wait, what were we talking about again?
Someone makes up some bullshit about 30fps and the guy writes an article about it? That's like someone saying "when you flush a toilet and the water hits you in the face it's not only acceptable but healthy". Then someone writes an entire article about it but comes to the conclusion that poop filled toilet water is actually bad but you won't die from it.
Just... no.
I have yet to play a game that would better at 30fps...not counting those games that are buggy over a certain framerate.
Framerate doesn't affect atmosphere and if anything, slower paced games look even better when they're actually running smoothly.
The 30fps trolls need to go away before they ruin everything.
So much this. I have never stopped and thought, "You know, this game would be much more cinematic and enjoyable if I were not pushing more than 100 frames per second." You can obfuscate it all you want with motion blur and such, but you can't hide the unresponsiveness of a game running at 30 FPS. I had to stop playing The Evil Within because of this.
Basically it's an argument for such a setting to be put in so that people with shitty computers can play without extensive tweaking.
Moron: "Crysis 3 runs like ass on my 2 year old tablet!"
Us: "Well...DUH?"
The consoles are so disappointing this round. They were supposed to handle 1080p last gen and they still can't.
Certain games are fine at lower FPS.
Civ 5, for instance, is perfectly playable at 15fps.
For multiplayer FPS - however - a minimum framerate of 60fps is needed. No doubt about it. If it drops under 60fps for even a second, it is unacceptable.
I'd say, you can get away with 30fps in a single player FPS, though. It's more about the experience, so if there is a framerate vs. eye candy tradeoff, I'd crank up the eye candy here.
Agree with this.
While certain games are certainly playable at lower framerates, the higher the better...
I think it's a great idea. nvidia is already doing it to make laptops run cooler and to last longer on batteries so why not? It's not like all the people who want to won't be able to turn it off or something if they do the whole "typical gamer scream-y pout-fest" over a thing they don't like in the event that the setting is on by default and can't be turned off.
I can play some games at 30fps no problem. Most games in 3rd person I prefer in 30fps over 60fps. I also notice games that use a controller for I can tolerate 30fps for the most part. Like Assassin's Creed, GTA, and Sleeping Dogs I preferred them in 30fps. But if I'm using a keyboard and mouse and playing FPS, I can't tolerate anything below 60fps.
I have one for you to try, In Far Cry 4, there is a advanced graphics setting for 30 fps vsync called 'sparse' instead of normal. I can normally play it maxed out with 60fps avg, but sparse just locks it at 30 fps and it is a HORRIBLE experience compared to 60 fps. Go ahead, check it out, shame on this author for promoting a stale market.
Except for they couldn't. None of the last gen games were 1080p. I think the highest was around 800p but usually they were 720p.
The new consoles handle 1080p sometimes. Destiny is 1080p, Halo: MCC is 1080p, Diablo 3 is 1080p, GTA5 is 1080p, etc.
Although I do agree that the hardware is a little dissapointing, it is true that graphics alone don't make a game good.
I'd prefer to play games in 60fps, but the reality is almost every game I play runs at or close to 30fps. My personal preference is for a single card solution running the game with graphics details at max and at 2560x1440. Basically the only thing my rig runs at more than 40fps or so is old stuff like Counter-Strike. I'd have to compromise on image quality or spend a lot more money and time messing around with a multiple card system to get better, and I'm just not willing to do it.
30fps was rough 10 years ago - it's still rough now. If developers start locking their games at 30fps i'll never buy another shitty port from them again.
I mean I get the idea behind 30 fps. It's just like movies at 24fps, it has a certain cinematic feel to it. I remember after years of playing Final Fantasy on PSX I was used to the 15 fps CGI cut-scenes. Then when I saw a 30 fps cutscene on PS2 I thought it looked weird as hell, but got used to it pretty quick. Games like Assassins Creed do have a certain feel to them when run at 30 fps, the crowd appears more natural and so forth. But then again, when viewed at 60 fps the buttery silky effect is superior in its own way. If dev's want to plan for 30 fps as their blueprint for detail, thats fine, but dont like CAP it at that. If someone has the horsepower to run at 60 fps then why the hell not?
This. This is a lame copout by developers for weak console hardware and poorly coded games. 30 FPS is right on the edge of what most people would consider playable, and judging by AC Unity, they're having trouble even achieving that consistently.
Dont console gamers have a choice of 720p 60hz or 1080p 30hz or 1080i 30hz? Can they even play at 1080p 60hz?
I mean I get the idea behind 30 fps. It's just like movies at 24fps, it has a certain cinematic feel to it. I remember after years of playing Final Fantasy on PSX I was used to the 15 fps CGI cut-QUOTE]
Except its not, if a game can't do better than 30 fps, its not going to be able to add cinematic grade motion blur to it. cut-scenes can get motion blur off-line, even prescripted motion could potentially do it, but there's no way to do it real time reliably. Especially with spontaneous direction changes possible. You may be able to do a little, but not approaching cinematic.
FPS is like horsepower, sure there's a market for the Honda Fit, but ours entire driving experience is enveloped by the Lambo, with so much more on top.
Rationalizing the Fit over the Gallardo is a fool's errand when evaluating racing capability.
Yeah, sucks when video is too smooth. Gaming is like milk, its better when its a little chunky.
When it came to those titles it did make "too smooth" for me. Almost like watching a soap opera, or the smoothing effect that TVs do that drives me crazy.
There's also a case to be made for games using 256 colors.
Talk about lazy publisher BS arguments.
Digital Foundry isn't anti-60 fps, but they are for v-sync and against fluctuating framerates. That's why they're advocating for a 30 fps limit option - because otherwise gamers who can't maintain a constant 60 fps have to put up with a constant fluctuation between 30 fps and 60 fps when they turn on V-sync.
Pffft, 30fps is just for epeen. That's 30 frames every second people, how many do you really need? I doubt anybody here can notice anything higher than 15fps.
What kind of video card are you running? I too run a single card system, but I use a GeForce 780TI...I play at 2560x1440, and most games I can get 60fps easily with a level or two less of AA and whatnot. Still have almost everything else turned up to ultra.
Oh dear.
I sure as shit can notice.
Factory overclocked Gigabyte Geforce 780 (GV-N780GHZ-3GD). For example, right now I'm getting 37fps average in Dragon Age Inquisition benchmark with details maxxed out.
The soap opera effect is from interpolation the TV does to make a lower fps source artificially smoother to say 120Hz or higher. Video game frames are all rendered, there is no interpolation and therefore no soap opera effect.
Probably MS behind this to try and keep the shitty X1 relevant for the next six years. Obviously the consoles wont be able to hold water against the PC now or the next six years. Hell, smartphones and tablets will probably outpace them by then.
I set The Evil Within and Shadows of Mordor to 30 fps. I would prefer to have the performance boost.
There are still extra frames no matter how look at it, which still smooths it out. Just because the extra frames are rendered versus interpolated, that doesn't negate the display is giving a smoother appearance.
There is no performance boost in capping the framerate. In fact, your video card(s) will operate using less power when limited in this manner.
Just panning around at 30 fps is a stuttery pile of crap. How in the heck anyone can say they prefer 30 fps is beyond me.
Even in console games its quite noticeable. I was just playing Last of Us on PS4 and you have the option to run locked 30 fps or unlocked framerate. Its NIGHT and freaking DAY the difference.
Here is a Last of Us comparison video but in person its even more noticeable. http://www.ign.com/videos/2014/07/28/the-last-of-us-remastered-lock-at-30-fps-graphics-comparison
Okay, I guess I should have said that I wanted to put less stress on my hardware. I can't stand hearing the fans on my card going.
