ChingChang
- Mar 27, 2003
Some games, especially newer ones, will perform better with 1gb ram. And the ram really helps out if you multitask
few would be coded to take advantage anywayMrDigital said:If you use that 4GB to run a SQL Server, great. If you do some weird billboards in Photoshop that are 4GB+ files, great. If you do 3D work that involves a lot of textures, great.
If you're going to tell me that games run better on 4GB, well.. I'll skip that.
-MrD
... all user applications together can only access a total of 2 GB of combined physical and virtual memory (with virtual memory in this case referring to HDD space allocated to the page-file).
These limitations apply to WindowsNT, WindowsXP and Windows Server2003 (Windows.net). ...
phaelinx said:.I hope this turns into a flame thread because this ROOKIE deserves it.
LMAO Well I wasted my money on a GIG of Corsiar, And I would waste it again if I needed to.MrDigital said:1GB is a waste. The only people who say otherwise are those who already wasted their money on 1GB and need to justify it to themselves. You won't need 1GB until Longhorn.
-MrD
A 3.2Ghz P4 and a 9800 Pro is generally a waste for home users doing nothing but surfing and gaming. So is 3 printers, PCI-X, dual gigabit lan, 2 SCSI 15K RPM HDs, an Audigy ZS Platinum, 500+ Gbs of storage space, 3 optical drives, a top of the line 510W PSU and 2 21" monitors. Does that mean you wasted money on your setup? No, it just means that your needs differ from the average home user's.MrDigital said:If any of you actually took a look at the machine I'm running these comments of "he just can't afford 1GB" wouldn't be happening. I spent more on my motherboard than most do on their RAM. It's not an issue of affording it. It's an issue of waste.
Do I order a 32oz porterhouse steak and eat 10oz of it and throw it away, simply because I can afford it? No. I order what I need.
There will come a time when 1GB is needed. Maybe it will be in the next 6 months, but I doubt it. If those of you with 1GB (for gaming) right now want to believe it makes a difference, more power to you. But I will continue to try and inform new builders that it is a waste until the day it is not.
-MrD
SO I take it you needed the 2 Seagates for web surfing right??MrDigital said:If any of you actually took a look at the machine I'm running these comments of "he just can't afford 1GB" wouldn't be happening. I spent more on my motherboard than most do on their RAM. It's not an issue of affording it. It's an issue of waste.
-MrD
I occasionally do my forums stuff on my machine, so i find the extra ram a big difference from the old 512 Megs i used to have.Ice Czar said:few would be coded to take advantage anyway
64-bit Computing in Real Life
Opteron memory Guide
Photoshop is limited internally to 2GB (as a process)
whereas say Renderman Pro Server (3D backend) can employ greater than 2GB
and alot more will likely be ported soon
you forgot video editing, and encoding
as I said before I dont Game, so I really have no benchmark to determine what kind of decrease in game performance your describing by having more RAM
but I know quite a few members have rigs that do alot more than just game
and a 1GB Id call a minimum, especially in the Higher end processors
(obviously paired in the Dual Channels)
folks are just too likely to be running a few dozen processes at once
a few of them potentially intensive
this is fun > How the Dell Model Cripples ComputingAnd Drives the Industry. @ Sudhain
I sort of rememver the flame fest between a bunch of us and some guy named Tanks.Ice Czar said:do to big muddy moderator tracks
flaming has been postponed indefinately
and now for the weather,
tonight widespead darkness
phaelinx said:ps. I'm a rookie? I been building computers since apple IIe's, and whos the noob with the 56k modem in their pc? you still on dialup? or do you like having it attached to your pc sitting there taking resources? If you use it for faxing, ever heard of efax.com?
XSNiper said:I think MrDigital thinks that the extra ram gives you higher FPS. Game performance is a combonation of your system including: RAM, Video Card, CPU, and maybe even Sound Card. RAM- Makes transitions between loading, new menus, etc. faster. Video Card- higher FPS at higher res. at higher settings. CPU- Most everything including AI. Sound Card- higher quality sound and can have an impact on FPS good or bad. RAM DOES NOT MAKE YOUR FPS MUCH OR ANY HIGHER! IT STRICTLY SMOOTHNESS FROM ONE SCREEN TO THE NEXT!
ps. MrD this is an unwinable war it doesnt matter how crappy your PC is and how much money you have, its just a fact the higher amount of RAM IS BETTER no matter how much you try to say its not or is a waste.
Neocorteqz said:SO I take it you needed the 2 Seagates for web surfing right??
Ice Czar said:folks are just too likely to be running a few dozen processes at once
Ice Czar said:actually Id say you underestimating the encoding and burning crowd
and not mp3, video encoding DivX et al
serious multi tasking easily requires 1GB given the OS and assorted resident programs hog so much,
Im not doin much of anything right now
just watching a mounted DVD image and surfing
however
Running processes:
C:\Program Files\SpyBlocker Software\spyblocker.exe
C:\Program Files\SpywareGuard\sgmain.exe
C:\Program Files\SpywareGuard\sgbhp.exe
C:\ZARK\ARK\SCN\HijackThis.exe
MrDigital said:Yes rookie, you made a statement about me being on my Mommy's PC. Unless my mom has a Supermicro workstation motherboard and PCP&C 510 PSU, you obviously have no idea what you are talking about.
Not only that, but if you actually READ instead of scanning, you would notice my modem is a US Robotics Courier, the single greatest modem ever invented. I use it for e-faxing, and when necessary, internet access (if the cable modem dies). It doesn't take any resources other filling a serial port that would otherwise be unused anyhow.
BTW, what did Apple think of you building Apple ][e's? They should give you a medal for being the only person able to do it since Apple's didn't have any clones back then.
Anyhow, keep the replies coming, it's pure comedy.
-MrD
phaelinx said:No where in my comment did I say I was BUILDING Apple IIe's did I?
phaelinx said:I been building computers since apple IIe's
MrDigital said:Certainly sounds like you've been building PC's since the Apple ][e's. If you've been USING computers since than, you could say as such.
And if you don't need a dial-up connection to access the net if your broadband goes down, more power to you. You obviously don't do anything critical and/or productive online. I on the other hand need to make sure I can access the net at any given time because my occupation depends on it.
-MrD
is there some kind of test out there that can prove one way or another that more ram is less or more benificial?Ice Czar said:phaelinx stick a sock in it yourself
making unfounded accusations wont be tolerated
but lets see to answer your question
graphic design, cgi, and video
mvfalcons21 said:Okay, I have been having some trouble choosing between 1GB of RAM or just 512MB. My computer right now has 512, and it's pretty good. I have heard that some games won't even run without a GB. Any insight would be helpful.
phaelinx said:I have a gig of ram setup as dual channel, things load faster, hd spins less, If I had known a gig of ram was this helpful I would of gotten it years ago..trust me, get a gig of ram...you will thank me. I use my pc mainly for gaming and having a gig of ram makes games run so much smoother
XSNiper said:MrD this is what started all this.
This is what ended it.
We don't need some one who is dirt poor because they spent so much on there modem to come in here and say that 1gb is a waste.
Neocorteqz said:is there some kind of test out there that can prove one way or another that more ram is less or more benificial?
I have over a gig and noticed a difference as well. also the less paging you have to do, the faster the load time will be. plain and simple. There is a little thing in XP that will alow you to select what you'd like you memory optimised for. Background services, or Programs.Wolf-R1 said:I can see that this thread has degenerated into a pissing contest.![]()
Personally I think that 1gig is just slightly more than enough. I think the day where games want larger texture caches is now and it started with Doom3 and it's Ultra setting wanting 512mb caches. Other than texture cacheing for what few games exist that can handle it...more than 512 is marginal and over 1gig is a waste.
Personally I have noticed an improvement in games when moving from 512M to 1G which was nice but it doesn't really do much beyond that.
Of course that mindset doesn't speak to those that are rendering/editing/etc multimedia content.![]()
phaelinx said:MOST occupations don't require all the senseless garbage attached to your pc..and When has a occupation required a Lian Li 6 in 1 reader?? Or a 9800Pro? hmm? or 2 dvd burners? thats some heavy illegal occupation you got going on there..downloading movies, burning them and selling? I'd trade all the nonsense for another stick of 512 in a heartbeat.
XSNiper said:We don't need some one who is dirt poor because they spent so much on there modem to come in here and say that 1gb is a waste.
MrDigital said:Seriously, take your head from wherever it is
