the 650i or ds3 for ocing?
im sry disregard this i figuredit out myself but if someone could tell me how to delete a thread that would be much appreciated.
I'd say the DS3 is probably a better OCer, but the 650i is a good budget OCer and has SLI. Really depends on your budget and needs...and what CPU you're putting in it.
I went with the DS3 because of the vdroop problems with the Asus 650i board. I don't need SLI either, so it was a good choice for me.
If you're going to OC an E6300 on a DS3, I'd look at getting some Cas 4 DDR2 800 memory. If you go past 2.8Ghz your memory is going to start going over the DDR2 800 limit and might hold you back if you get cheap stuff.
If you don't want to spend the extra money on memory, you should look at getting the E6400 with a larger multiplier or the E4300 with a smaller FSB.
Yep. My 667(333MHz) ram is holding me back. I still got up to 3.3/3.4, though.
Sorry...noob question from a guy considering buying the 650i Asus board: what is 'vdroop'? And would it affect a guy who is not going to be OC'ing?
Vdroop is usually when the Vcore voltage doesn't actually read what you set it to in bios. It's pretty common in Asus boards. On my P5W, I set my Vcore to 1.375V, and I get 1.33-1.35V in Windows. Sometimes CPU's need extra voltage to be stable, and they aren't getting it even though you set it in bios.
It shouldn't affect you if you're not OCing.
