tforce 6100 doesn't like dual channel?
chambersc
I'm running the SFF in my sig. I put the 2x512mb sticks of the 222 special RAM into the slots DIMMB 1 and DIMMA 1 slots. i booted up and it would run for like 10seconds then constantly reboot. i took the RAM and put em in DIMMA 1 and DIMMA 2 and they're working fine, but running at 163.6mhz single channel. Should i increase voltage and try the dual channel? is it my ram? is it the mobo?
Make sure your not using the stock PSU, exchange it for a good one.
Make sure you're not using the B02 bios, use bios M20 for mushkin ram.
the stock PSU sucks? meh, seems to be alright for me. i'm not drawing THAT much power. the 420w seems alright to me. about the BIOS, i'll look up on that.
Hmmm...I put mine in Dual channel while building it, it fired right up, no probs. I ditched the stock PSU tho, I have an Enermax 525. Could be PSU or the memory incompatable. Bad mobo, too I suppose.
mine runs fine with pqi turbo tccd 512mbx2 and with ocz gold pc3200 bh5. but will not boot into windows with g.skill la tccd or corsair pc3500 v1.1 bh5. go figure. nf4 chipsets are picky when it comes to ram.
my stock aspire psu has been running fine for about 7 months with a 3500 venice, 6600gt, 2 hard drives, 2x512mb ram, 1 dvd burner, first with the ecs radeon xpress 200 board and now with the tforce 6100-939 with a nice oc. but some folks do have issues.
i have a tforce running dual chan.... make sure they are in the yellow dimm slots....
2-2-2 memory probably needs a slight bump in voltage to run at rated speeds.
I am using two sticks of 1GB cheapo Advance Modules high density in dual channel just fine.
OC'ed to 225mhz 2.5-3-3-7 @ 2.8
High density didn't work until the bios after 929
Using B02 bios just fine too despite compaints from others...
