Testing Dual Core OC Stabliity
Rudager
If you're running Prime95 or SP2004 to check the stability of your overclock...is it a good thing to run two iterations of either program to work both cores?
run two iterations of prime 95 and make sure to set the "affinity" setting to one cpu each. that way it will test the stability of both the cores.
you guys run the latest version of prime at what settings??
Small FFTs is the setting usually used for proc stability. For dual cores, run another instance and set each instance's affinity to one core each.
