Okay, so my 9 year old daughter decided to be 'helpful' and powered off my running computer (including a number of running programs) by hitting the power button until it shutdown. Unfortunately, when I powered it back on the computer had a number of issues. It ran a system file check on the C:\ drive, and two of the three other hard drives were missing when I managed to get into Windows. I ran a couple programs before I noticed strange behaviors (programs taking longer to load, I was unable to access the Recycle Bin, and similar issues).
I rebooted the computer, and again it ran the system file check. Once that completed, everything seemed to work. For a couple hours. The next day, I had similar issues but the system file check didn't need to run.
Last night (three days after she shut down the computer), I noticed that the CD-RW doesn't recognize discs. But it will eject upon request and spin up when I put in a CD. One hard drive went missing last night. Twice. After rebooting in order to find the HDD, the system file check ran again.
I'm guessing that the method used to turn off the running computer has caused issues with hardware. Since its not limited to just one HDD, I think its the motherboard.
How do I test this? I unfortunately do not have a spare PC to plug everything into in order to check.
