StratocasterMaster
- Nov 23, 2000
I have a system I've used for just over a year now but I am having issues with it that are causing me a lot of stress. I recently reloaded Windows at a LANparty as my brother had infected me with some violent spyware but the installation rebooted partway through, it continued normally so I just left it be since I was in a hurry and had no issues.
However a few weeks after I started having issues with games (Mainly World of Warcraft) where after a bit of gameplay it would just lock up, black screen and reboot. First I blamed Windows and have been unable to reinstall due to lack of CD at the moment but it doesnt crash in anything else... I've reinstalled WoW and done all the updates but to no avail. Then I looked to my PSU as the voltages were out of wack to me but many say they are in the +/- 10% range so its not an issues. Now I'm looking to my CPU or the rediculous tempuratures it is operating at.
The highest temp I have recorded so far has been 67c during WoW gameplay before a crash and somewhere between 59-61c during idle in WindowsXP
rofessional. My cooler is currently the OEM Intel cooler with ArticSilver2 applied. (After cleaning off the OE TIM of course). Now I will say that my house is slightly warmer than usual but nothing rediculous and my system (Northbridge) temps are stable at 39c idle temp. My video card (Radeon9600xt) is running around 48c when I check from the ATI overdrive panel. I dont understand how my CPU can be peaking almost 20c higher than room tempurature or system temp.
Now I was previously utilizing watercooling with a Maze4 waterblock, BlackIce 120mm rad and Eheim 1048 but my temperatures were no better with that setup either. Does this chip run horribly hot by nature and is not my issue or is there something else amiss here?
System specs:
Antec TruPower 430w
Pentium 4 2.8e 'Prescott' -- OEM Intel HSF
Abit IS7-e mainboard
512mb GEIL 'Golden Dragon' DDR400 (2x256) (Default timings)
ATI Radeon 9600xt (Omega Drivers, latest form)
SoundBlaster Audigy 2
WD 120GB HDD (Primary) PATA
WD 160GB HDD (Secondary) PATA
Plextor DVD/CD-RW
LG DVD/RW D/L
Four-fan Rheostat bus
Two 80mm UV fans + One 120mm Sunon
Windows XP: Professional SP1
That is EVERYTHING running inside my case at the moment. My PC is currently not overclocked however it was previously overclocked to 3.3GHz at 1.65vcore. I know that Windows is being a variable but I think my temps are a cause of some concern if not the root of my issues, which may have been the reason for Windows locking up during install. I appreciate any info that can be provided.
Thanks,
~Kris
System specs:
Antec TruPower 430w
Plextor DVD/CD-RW
LG DVD/RW D/L
Thanks,
~Kris
