Temps went up after cleaning.
mrwill
I have a large case, Coolermaster ATCS 840 with a Corsair H100 cooler that uses 4 fans in a push/pull configuration. Temps were at 45°C at idle, and 75°C under full load (video transcoding). Today I decided to clean the inside and change the direction the push/pull was blowing. I thought my temps (45/75) were too high and the cooler direction was blowing out. The Corsair radiator was very dirty, so I cleaned that and switched the direction of the 4 fans to blow in. My temps went to 65°C at idle to 86°C under load. Then I decided to replace the thermal paste since it has been about 3 years since I built this. Did that, and the temps are now 50/80. I switched the fans back so they are blowing out again and that did not change the temps. Any idea what is going on?
By the way, about 2 months ago I added a fan controller and an exhaust fan at the rear of the case. The fan is adjustable up to 182 CFM. It is very loud at full throttle, but it does not even change the temps one degree.
Those are pretty high at idle. Is the pump plugged in for the h100, or possibly dead? Wouldn't matter if your fans are working at 100% if the pump isn't flowing water correctly.
That might actually be a good explanation. I might have dislodged something by moving it around.
How would I check this since it is a sealed system? And how would I check the pump? It's not easy as all the case fans make it impossible to hear if it's running.
Can you squeeze the coolant lines? The less pump flow the higher the pressure. If the lines are hard as rock then I'd say the pump is stopped up.
It would be the opposite actually. As you squeeze the line, you increase the resistance to flow and pressure increases as the water tries to force its way through the blockage.
What you are thinking of is when there is flowing water in standing water (or air), the flowing water is at a lower pressure compared to the standing water/air. This is not applicable when the water is enclosed as in a CLC.
You could pull the power for the pump to validate any variation in the temperatures. I am going to guess that they do not change.
I pulled the power to the pump. The temps shot up and I had to shut it down. I hadn't noticed before, but the pump was making a pretty loud noise, so it's probably failing. I called Corsair and they have a new one coming to me - since it was in warranty and I did have the receipt. Since they don't make the H100 any more, they are sending an H100i.
Question: Is there a more efficient cooler similar to the H100i (and at the same price point) ?
NZXT Krakens would be your other choice. But top end CLCs will perform similarly to top end air.
What are the top end air systems that would be equivalent to the H100i?
Top air coolers are better than H100i .. most by several degrees and even more when H100i fans are slowed down to same noise level as top air. This was discussed on a thread here just over a week ago.
http://hardforum.com/showthread.php?t=1837266
Here is a list of some of the top cooler sizes and clearances. Some are better than others, but all are within 5c of each other.
Code:
Cooler size comparison
(Width x Depth x Height looking from front of case with motherboard laying flat)
    Cooler		 Heatpipes     Size W/O Fans	  	 Fans	       RAM Clearance*   CPU-Frt**     CPU-PCI-E***
Akasa Medusa		8x 6mm OD  144 x 129.5x163mm    140mm & 120mm PWM fans     54.6mm	   64.3mm
Cryorig R1 Ultimate	7x 6mm OD  140 x 142.4x168.3mm  XF140(140x25) fans	   35mm		   40mm *2*	70mm
Cryorig R1 Universal	7x 6mm OD  140 x 130 x 168.3mm  SF140(25mm) & XT140(13mm)  35mm		   35.5mm *2*	70mm
K2 / Assassin		8x 6mm OD  140 x 128 x 158mm    120mm & 140mm PWM fans     48.2mm	   64mm		70mm*4*
Dark Rock Pro 2		7x 6mm OD  138 x 124 x 166mm    120mm & 135mm PWM fans
Dark Rock Pro 3		7x 6mm OD  137 x 150 x 163mm	120mm & 135mm PWM fans	   44mm		   51.5mm	69mm*4*
NH-D14			6x 6mm OD  140 x 130 x 160mm	120mm & 140mm fans         49mm		   62mm		70mm*4*
NH-U14S			6x 6mm OD  150 x  52 x 165mm     + fans		   	   46mm		   26mm		75mm*4*
NH-D15			6x 6mm OD  150 x 136 x 165mm	2x 140mm fans		    *1*		   67.5mm	75mm*4*
PH-TC14PE		5x 8mm OD  140 x 159 x 171mm	2x 140mm fans, PWM adaptor 45-50mm	   72mm		70mm*4*
Megahalem		6x 6mm OD  130 x  74 x 158.7mm	+ fans			   39.50mm	   37MM
SS HE01			6x 6mm OD  140 x 119 x 160mm	1x 140x38mm PWM fan	   47mm		   47.5MM *2*
Archon SB-E		8x 6mm OD  155 x  53.6x170.2mm	+ fanS			   42.35mm	   26.8mm	77.5mm
Archon IB-E		8x 6mm OD  155 x  53.6x165.2mm	+ fans			   48.2mm	   26.5mm	69mm 8.5mm***
Silver Arrow		4x 8mm OD  147 x 123 x 163mm	2x 140mm fans		   45.87mm	   61.4mm	73.5mm
Silver Arrow SB-E	8x 6mm OD  155 x 105 x 164mm	mid 150mm/frt 140mm PWM	   36.9/44/51mm*3* 51mm		77.5mm
SA SB-E Extreme		8x 6mm OD  155 x 105 x 164mm	mid 140mm/frt 140mm PWM	   36.9/44/51mm*3* 51mm		77.5mm
Silver Arrow IB-E	8x 6mm OD  154.6x103 x 164mm***	2x 140mm 1300rpm fans	   46.95mm	   51.5mm	67.8mm
SA IB-E Extreme		8x 6mm OD  154.6x103 x 164mm***	2x 140mm 2500rpm fans	   46.95mm	   51.5mm	67.8mm
TRUE Spirit 140 Power	6x 8mm OD  155 x  53.4x170mm	+ fan			   49.3mm	   26.5mm	77.5mm
HR-22			8x 6mm OD  150 x 120 x 159mm	+ fan			   41mm		   -1mm		70mm  5mm***
* add 3mm for motherboard to bottom fin
** center CPU to front of cooler W/O fan
*** Center CPU to PCIe side (base is off-center for better PCI-E slot clearance)
*1* recessed lower fins, the NH-D15 provide 64mm RAM clearance
*2* offest back for better RAM clearance
*3* fins are at 3 different levels
*4* fan clips add additional 3-5mm
I've tried to be as accurate as possible, but if you notice anything that's not correct please let me know.
Here is temperature comparisons. Several new coolers are not on the list like Cryorig R1 Ultimate, Thermalright Silver Arrow IB-E, TRUE Spirit 140 Power, Anchon IB-E X2, Dark Rock Pro 3, etc.
Code:
CPU Cooler Temperature Database
	Cooler			Fans 	Fan Model	RPM/CFM		345.1W 	289.9W	232.1W	175.4W	117.1W	 dBA*
									  Temperatures	  in	   Celcius
Cooler Master Nepton 280L 	2x JetFlo 140 		2000 / 122.5 	17.1 	14.6 	11.9 	9.2 	6.2 	55.8
Cooler Master Seidon 240M 	2x DF1202512RFUN 	2400 / 86  	20.2 	17.1 	14.1 	10.4 	7.9 	50.7
Silverstone Tundra TD02 	2x AS1225H12 		2500 / 92.5  	20.6 	17.6 	14.6 	10.7 	6.9 	49.6
Corsair H105 			2x SP120L 		2700 / 3  	21.5 	18.5 	15.8 	11.9 	8.5 	54.3
Corsair H110 			2x 	? 		1500 / 94  	22.5 	19.3 	16.0 	12.1 	8.8 	48.7
Corsair H100i 			2x SP120L 		2700 / 73  	23.8 	20.5 	17.0 	13.0 	9.9 	54.3
NZXT 	Kraken X60 		2x FX-140 		2000 / 98.3  	23.9 	20.8 	17.3 	12.9 	9.0 	51.2
Corsair H100 			2x 	? 		2500 / 92  	24.4 	20.6 	16.7 	12.9 	9.0 	51.2
Noctua 	NH-D15 			2x NF-A15		1500 / 82.5  	24.0 	21.1 	18.0 	13.7 	10.1 	41.5
Cooler Master Seidon 120XL 	2x DF1202512RFUN 	2400 / 86  	25.5 	21.2 	17.2 	13.2 	9.0 	53.2
Akasa 	Medusa 			1x AK-FN059 		1900 / 84  	26.7 	22.5 	18.7 	13.7 	10.1 	48.1
				1x AK-FN073 		1600 / 110
Thermalright SilverArrow SB-E 	1x TY-150 		1100 / 84  	26.9 	22.8 	18.7 	14.1 	9.5 	37.4
				1x TY-141 		1300 / 74
Noctua 	NH-U14S 		1x NF-A15		1500 / 82.5  	27.0 	22.9 	19.4 	14.9 	10.6 	35.8
Phanteks PH-TC14PE Black 	2x PH-F140 		1300 / 88.6  	27.4 	23.5 	19.2 	14.1 	9.9 	41.3
Antec 	KÜHLER 1250 		2x 	? 		2400 / 98  	27.4 	22.9 	18.9 	14.9 	10.9 	54.4
Be Quiet! Dark Rock Pro 2 	1x T12025-MF-PWM 	1500 / 67.8 	28.2 	25.9 	20.2 	16.4 	11.2 	38.2
				1x T13525-MF-PWM 	1700 / 57.2
Cooler Master Eisberg 240L 	2x SA12025SA2 		1600 / 60.2  	28.9 	23.6 	19.6 	15.0 	10.3 	48.5
Thermaltake Frio Extreme 	2x PLA14025S12H 	1800 / 106.2 	29.3 	24.8 	20.4 	15.9 	10.7 	48.7
Enermax Liqtech 240 		2x ELC-LT120HP 		2500 / 111  	29.6 	25.2 	21.2 	15.9 	11.4 	57.4
Silverstone Tundra TD03 	2x AS1225H12 		2500 / 92.5  	29.7 	24.9 	19.8 	15.5 	10.7 	51.4
Prolimatech Megahalems BlkViper	2x AK-FN059 		1900 / 83.6  	30.4 	25.8 	23.4 	16.0 	11.5 	46.5
Noctua 	NH-D14 			1x NF-P14 		1200 / 64.9  	30.6 	26.2 	21.3 	16.3 	11.8 	38.2
				1x NF-P12 		1300 / 54.3
Antec 	KÜHLER 920 		2x 	? 		2400 / 110  	30.8 	27.0 	22.8 	18.6 	14.0 	60.5
Scythe 	Mugen 3 		1x SY1225SL12M-P 	1200 / 68.54  	31.0 	25.6 	21.3 	14.8 	10.8 	42.7
Xigmatek Aegir (SD128264) 	1x PLA12025S12M-4 	2200 / 89.45  	31.1 	26.0 	20.5 	15.2 	10.3 	45.9
Thermaltake Frio OCK 		2x EF RB14025SH 	2100 / 121  	31.3 	26.7 	22.1 	18.1 	13.1 	41.1
Corsair H90 			1x SP140 		1500 / 94  	31.5 	26.3 	21.8 	16.5 	11.9 	59.3
Silverstone Argon AR01 		1x AS1225H12 		2200 / 81.40  	31.7 	26.9 	22.3 	17.4 	12.1 	42.8
Thermalright Ultra 120 eXTreme 	1x PLA12025S12M-4 	2200 / 89.45  	32.1 	27.0 	22.5 	17.0 	12.0 	45.9
Enermax Liqtech 120X 		2x ELC-LT120HP 		2500 / 111  	32.4 	26.9 	22.3 	16.9 	12.2 	57.3
ELC-LT120HP 	2500 /111
Prolimatech Genesis Black 	2x PH-F140 		1300 / 88.6  	33.1 	24.4 	19.3 	14.2 	9.7 	41.7
Xigmatek Dark Knight SD1283  	1x A1225H12S 		2200 / 89.45  	34.4 	28.8 	23.5 	18.1 	12.8 	42.8
(Night Hawk Edition)
Alpenfohn Matterhorn Pure 	1x 	? 		1500 / 108  	34.5 	29.1 	23.8 	17.9 	12.6 	39.8
Noctua 	NH-U12S 		1x NF-F1		1500 / 55	35.3 	29.9 	24.9 	19.0 	13.7 	37.3
Corsair H75 			2x AF120L 		2000 / 54 	35.4 	29.6 	24.9 	19.0 	14 	44.8
Antec 	KÜHLER 650 		1x 	? 		2400 / 98  	36.2 	30.5 	24.9 	20.1 	14.9 	47.4
Scythe 	Mine 2 			2x SM1425SL12H		1700 / 92.4  	37.7 	31.7 	25.9 	19.7 	13.8 	38.0**
Cooler Master TPC 800 		2x PLA12025S12M-4	2200 / 89.45  	38.6 	30.1 	22.6 	15.8 	10.6 	43.1
Prolimatech Panther 		1x RL4R S1202512LNP-4M 	1600 / 72.7  	42.0 	35.9 	29.6 	21.8 	16.5 	41.5
Antec KÜHLER 620 		1x 	? 		2000 / ?  	42.0 	35.5 	29.4 	22.6 	16.1 	43.1
NZXT HAVIK 140 			2x 	? 		1200 / 90.3  	42.3 	35.7 	29.0 	22.7 	14.7 	42.5
Be Quiet! Shadow Rock 2 	1 BQ PUW2-12025-MR-PWM 	1600 / 51  	45.4 	39.7 	32.8 	25.7 	19.4 	38.3
* Measured at 0.5m distance
** Measured with old db meter (not accurate)
http://www.thelab.gr/heatsinks-coolers-watercooling-reviews/cpu-cooler-review-database-89014.html
Agreed. That said, the H100i will be an improvement over the H100, if only for the reason that they changed the tubing between the two models. The H100 used this narrow, corrugated tubing, that was less flexible than that on the H100.
Personally, I'm a little wary about hanging all that metal off a vertically mounted motherboard, which is part of the reason why both my new cases have horizontally mounted motherboards. If that is a non-issue, and you have the space, and you don't mind the aesthetic, I would probably just grab an NH-D15.
Honestly the weight and size of big air coolers is not a problem. Almost everyone I know is using them and I know of nobody who has had any problems. Sure, if you knock it off the desk or drop in down the stairs something will probably break, but that's true of any system.
I'm using the NH-D15 .. as well as Cryorig R1 Ultimate, TRUE Spirit 140 Power, Archon IB-E X2, PH-TC14PE and Silver Arrow IB-E. It really isn't any better than others. Only reason it is a couple degrees cooler is the supplied NF-A15 1500rpm fans are faster than most other coolers use .. and the only way to get them is in a cooler package. The retail NF-A-15 is 1200rpm. Why Noctua has a 1200rpm and 1500rpom versions with same model number boggles the mind, but that is what it is.
An interesting bit of info is the NF-A15 and NF-A14 have same blade design and almost identical performance as Thermalright TY-140, TY-143 and TY-147 fans at same speed.
Just to add closure to this thread. I sent in my H100 and got the H100i replacement today. It is all installed now and I didn't realize how noisy the pump was on the defective H100. The new unit is much quieter and the temps are about 39°C at idle, and 59°C at full load.
