I swear, I think my temperatures go up slowly over time. I really don't know what could be causing this...
Right now in a room that's 74F, my Q6600, with a TRUE, is idling at 46C, 43C, 42C, 44C. Yes, you read correctly - with the best heatsink on the market I've got these really crappy temperatures. Load will get into the low 60s.
Now, over the summer when I first installed my Q6600, my room was slightly warmer. It was usually 77-78F, and at this speed my idle temps would be around 40C. So my ambients have dropped slightly since the summer, yet my temperatures are much higher.
I have however, made two hard drive additions since, and went from a 7900GT to a warmer 8800GT. But even with the new hard drive blocking some of the lower intake, I still have a completely unobstructed upper intake that supplies air to the RAM/CPU area. What exactly could have caused this large increase in temperatures. Dust is ruled out because my intakes are filtered and I clean those out on a regular basis. There's very little dust inside of my case.
Here's a picture showing temps of everything inside of my case... The only real idea about case temperatures I've got right now is AUX and GPU Ambient - both are recording ambient temps in right about the same area. I think 36-37C seems a bit high for a room that's 23-24C... even if the air is passing over 3 hard drives.
