It goes that everytime I fix one temperature problem another one arises...
The last temperature problem was with my CPU. I can say I have some nice air cooling power all around the system. It would idle way in the 40s and low 50s, load was around the 70s. Decided to switch the case, P182 to a Antec 1200, great news, idles low 30s, load at low 50s. Couldn't be loving the new temps any more, but now I noticed my GPUs were now in serious heat. Now my motherboard, evga 780i, was also another problem in my other case, but that wouldn't really affect the temperatures this high. My first 8800GT would idle in the 60s and loads in the 70 and even higher. Second card was better, not going much higher than 60 load. Those were my temperatures with zero overclocking on the GPUs. Can't even play a game without crashing within 10 minutes. I only had SLI for a while, and it doesn't seem worth it, even at my resolution@ 1920x1080. So now I want to get a new single slot GPU, new CPU cooler, and possibly a new motherboard. Even with around 9 120mm fans and massive 200MM can't cool down the GPUs and motherboard.
To sum it all up for people who can't follow that
* New CPU cooler
* New GPU
* Possible motherboard upgrade
I was possibily thinking a GTX280 and TRUE black edition?
I really don't want to mess with watercooling just yet. But I would like the most extreme, over the top air cooling stuff in my case ;]
System
Antec 1200 Case
eVGA 780i
Tuniq Tower 120
Q6600@ 3.15GHZ 1.24v
eVGA 8800GT 512MB SLI both with S1 REV2 coolers
Auzentech Prelude
4x2GB RAM @ 1000MHZ
* New CPU cooler
* New GPU
System
Antec 1200 Case
eVGA 780i
Tuniq Tower 120
Auzentech Prelude
4x2GB RAM @ 1000MHZ
