newls1
- Sep 8, 2003
OK, here is my issue with temperature reading on my C2D. To make a long story short, I have a E6300 using a Scythe Infinity cooler adn the chip is running @ 450*7 = 3.15GHz. The motherboard im using (gigabyte DS3) comes with EASYTUNE5 to read temps, etc... and it tells me im idling @ 26/27c loading @ 31/32c.
I've made another post the other day about these temps cause I was so happy that this chip runs as cool as it does, and you all told me this temp reading is WRONG! I was instructed to download an INTEL temp reading program called "TAT" i think..... and it tells me BOTH core temps in a nice windowed program are running @ 39/41c idle and 46/47c loaded. One more thing, I went into the BIOS after heavyly loading the system @ 3.15GHz, and even the BIOS says im @ 26c...... What is going on here. Which reading is the most accurate do you think? INTEL, EASYTUNE, BIOS???
Even if the intel program is right (or most accurate) are those still OK temps to have for this OC im using? Thanks everyone.....
