I'm running a 4690k with asusZ97-A being cooled by a corsair h100i. I let asus software oc the cpu to 4.5ghz. However, it seems my Temps are much higher than they should be. When just browsing the net and watching videos on you tube Temps hit the high 50s,when gaming Temps reach 60 to 70! I ran prime and occt and the Temps were getting too high that I needed to shut both down. Everything is inside of a corsair 450d with 2 stock intake fans in the front. The cooler is set with the stock fans that came with the cooler as exhaust on top and there is no rear case fan. I have 2 noctua fans that I want to swap with the noisy fans that came with the cooler. I'm not sure how the Temps are getting this hot with this huge cooler for the cpu...appreciate any help!
