Flagg said:Here is another safety tip. I learned this from watching another guy do it wrong.When you are cleaning a fiber. You typically use a microscopt (for lack of a better term) to look at the connector of the fiber. you can then see oil, dirt, grime and other nasty stuff and then use a clea-top <sp?> to clean it. MAKE SURE THAT THE LIGHTSOURCE IS POWERED OFF AT THE OTHER END OF THE FIBER!!! You see in single-mode fiber operations you are dealing with extremely high powered lasers thats are operating in the 1450nm range. Then add on to the fact that you will be looking through a microscope at 30x magnification. You can do some serious damage to your eyes looking directly into a laser like that, add to the fact that it is being concentrated through a microscopr and you get bad news.
