TD: Celeron D 356 $39.99 AR
Keep the P4. However, this Celeron will overclock better. It is a Cedar Mill, after all. :)
-40%
a 3.33 Ghz celeron is not superior to a 3.0 Ghz P4
In any way, Except for lower heat and price.
Um, i think you're way off there. Unless the P4 is a cedar mill, this can overclock further (especially considering it's lower bus speed and higher multiplier) and with 512k cache they're really not that far behind the P4's. It's not unheard of to hit 5ghz or more on a cedar mill celeron with good watercooling. Guarantee you that the celeron is far faster at that speed than the P4.
Now after all that, take into consideration the price.
Overclockability has jack shit to do with the stock performance of the processor.
No shit, sherlock, you are comparing a celeron @ 5 Ghz versus a P4 @ 3 ghz
How retarded do you have to be to be on this forum?
What happens if you overclock that P4 around 50% to 4.5 Ghz?
The question was how fast was this processor compared to a p4 3.0
not, "How fast is it if I overclock the fuck out of it" I'm sure if the asker of the question was running a water cooling rig, he'd have asked "how fast would this be at max overclock when compared to my 3.0C @ 4.7 ghz?", since he didn't, you should assume he's asking for a stock-for-stock comparison.
add the $250 minimum you are going to spend for a "Good" watercooling kit, and compare the price. Yeah, you can throw that $80 P.O.S. coolermaster rig at me, but I said GOOD watercooling.
Lets see : celeron d 356 = $40
What can I buy for $290?
Oh..
Maybe an e4300, e6300, e6400, hell, if i shop long enough, an e6600
All of those, even with a slight nudge (since the overclock like crazy even on air) will outdo that $40 celeron + the $250 you spent to extra cool it won't compare to what you get out of a C2D rig.
That being said.
a 3.33 Ghz CELERON with 512k cache and 533mhz fsb CANNOT compete with a P4 3.0 with 800mhz (or even 1066 mhz, depending on the cpu) fsb p4 with 1-2mb cache.
my old 3.06 (533mhz fsb, 1mb cache [sl9CA i think] lga775 ) overclocked to ~4.6 ghz (23x @ 800mhz fsb, rock solid. Should I compare that to the 3.0 too?
I'd venture to bet that even stock, my lowly 3.06 @ 533 WAS faster than that celeron, stock.
Check this thread
Specifically this image.
(Since, I know, nobody would ever believe a THG review)
Notice, this guy is running a 356 @ 5.436 ghz
Yet, his cpu only pulls 11K in aquamark.
But, back in -2003-, I pulled a 10,500 on a 2.4B @ 3.2 Ghz
Yeah.. that processor is smoking.
I could run tons of benchies for you, showing how, that even at 5 Ghz, this chip still sucks, but I don't own anything that low end anymore. I'd have to go find myself a 2.4b or something, AND get a 478 motherboard, too.
My a64-3000+ s754 laptop pulls a 6.2k running STOCK speed. Why is a processor running WELL more than DOUBLE the clock speed not doing WELL more than DOUBLE the cpu score?
//edited this above line. I originally said 8k, when in fact, my laptop pulls a 6.2K cpu score
an "inferior" processor. 5 minutes ago.
This site has evolved from "How far can I overclock" to "Whats the smartest purchase"
a lowly E4300 will smoke a celeron 356 all day long. And you don't even have to watercool it to do so, and if you know where to look, you can find them for ~$110-120 total out of pocket ($150 frys bundle + ebaying the board for $40 - ebay fees)
Right.
and the 805 (which isn't a 3 ghz stock processor, and is, in fact, a 2.66 ghz cpu) outperformed the celeron on the 3dmark cpu test.
What happens when you put it at 4.5 ?
What happens when you put a 3.06 to 4.7?
The Celeron D 356 has a clear Ghz lead but it doesn’t translate in better performance as it trails the other two configurations
Translation.. "Even though you can clock the Celeron D 356, to higher actual speeds, it still doesn't beat the "REAL" processors"
The 805 can go much higher than 3.9 ghz
That 3.9ghz was AIR COOLED. (read the article. They clocked it to 3.9 ghz due to a mobo limitation, even though their graph says 4ghz)
The celeron 356 was at 4.8 Ghz.. - a 23% clock advantage, and it still underperformed
CPU Test : 4.8 Ghz Celeron 356 : 550 points
Cpu Test : 3.9 Ghz 805D : 1122 Points
1122 / 550 = 2.04
The 805D is 2.04 x faster than the celeron, even though the celeron is clocked 23% faster than it.
Assuming that the 805d had been clocked @ 4.8 ghz [which is possible], it would have gotten around a ~1380
1380 / 550 = 2.5
Clock for Clock, the 805D is 2.5X faster than the Celeron 356.
The 805D costs $90
The 356 costs $40 after rebates
$90 / 40 = 2.25
The 805D costs 2.25 x the price of the celeron
The 805D performs 2.5 x BETTER than the celeron
More bang for the buck.
This ASSUMES that when you get the 805D to 4.8 ghz (or if you clocked the celeron to 3.9 ghz) the scores would scale accordingly.
Put it this way. As per these #'s, the 805D would have outperformed the celeron even if it (the 805d) hadn't been overclocked. [should have gotten in the 700s]
Like this guy, who pulled a 737 out of a stock 2680mhz "Pentium D" running at 133/533 fsb
So..
lets see.
Stock speed : Pentium D 805 @ 2.66 Ghz = 737 cpu marks
3.33 Ghz celeron @ 4.8 Ghz = 550 Cpu Marks.
Pentium D 805 @ 3.9 ghz = 1122
Pentium D 805 @ 4.8 Ghz = 1380
Hmmm? Which is faster
However its reduced cache size makes it slower than the competition even when running at close to 5Ghz! The new Celeron D will make an excellent competitor for AMD’s Sempron which has been regarded as the budget-friendly CPU… until now?
Thank you, mavalpha, for proving my point. I appreciate the help you gave.
This is, however, a GOOD PRICE, on this processor, none the less
I am considering it for my server :)
3.33 vs 2.53 might make a jump in samba, also, my celly 2.53 isn't EM64T I think.
805 is available with motherboard at frys for $79 pretty much every week.....and the mobo supports core 2 duo......
cyberdeus, your e-penis is so much larger than mine. my only question is, who pissed in your cheerios?
lighten up, fucknozzle.
ps - even on air the cellies will go far.
last i checked, the p4 3ghz is about $75. a cellie that will do, lets just be conservative and say 4.2, for $40, is a good deal especially as a hold-over processor until you make the leap to c2d. at least, a lot better deal than the p4.
i mean, if you're going to go netburst, might as well save your cash since those processors are all equally worthless.
1122 / 550 = 2.04
The ceiling for air cooling is around 4ghz on the 805s. Unless you're some kind of freak who likes the sound of delta fans.
What you're neglecting to mention here is that the celeron hit the same fsb wall, except it did so on STOCK cooling instead of an aftermarket heatsink, running at 1.4v instead of the 1.575 that the 805d needed.
1380 / 550 = 2.5
It's nice that you're good at math, but you're still not taking into consideration the cost of the cooler needed to keep that 805D from starting your motherboard on fire.
The 805D costs $75 + $34 for the same heatsink/fan combo. Oh, and since you're in a nitpicking mood, lets not forget about buying a good enough power supply to handle the 235 watt power draw as a result of pumping 1.575 volts through it.
The 356 costs $40 after rebates with a stock cooler, will overclock to 4.8ghz and beyond on 1.4 volts (144 watts!). You can overclock the bejesus out of these things with a microatx power supply
Also, I don't know about you, but I don't play aquamark or other benchmarks. Lets be realistic. Unless you're ripping DVD's or trying to feed an SLI setup (and in either case, why would you even bother asking about a celeron?), an overclocked Celeron is plenty fast. And I said overclocked celeron vs stock P4 3.0 because why the fuck else would you buy a celeron? Of course a P4 can be overclocked as well, but not as easily or as far on stock cooling -- unless you're talking about a cedar mill P4.
The question posed was "how much better is this than a 3.0ghz p4 at gaming".
Go to this thread:
http://www.xtremesystems.org/forums/showthread.php?t=102033
look at the celly 356 ON AIR@5436mhz results, then scroll down to where he compares cedar mill 651 to prescott 542@5ghz on DRY ICE.
Pretty close scores. c = celeron, p = prescott
3dm2k1: C=31904, P=32763
2k3: C= 22826. P=23219
2k5 C=10091, P=10281
Looks like the results reflect real world usage. The more stress placed on the video card, like if you were ACTUALLY PLAYING A GAME instead of RUNNING A BENCHMARK, the better the Celeron fares against the P4.
Looking through the rest of the results, something tells me that A) The celeron, easily overclocked on AIR should best a 3.0 P4 in gaming. Overlock the P4 on the stock cooler and hit the heat wall and maybe they would be about even.
then, B) the celeron is CHEAPER.
I mean, you say the p4 can hit those high clocks, and sure, it can... but at what cost? Dry ICE? Can you run that 24/7? didn't think so. Yet you can easily hit 5ghz on the stock cooler and higher with aftermarket air. Nevermind what you can do with good ram and water.. that's not really the point of buying a celeron.
All I was saying was that if I had to choose, today, between a P4 3.0ghz at retail cost, or a Celeron D 356 at this price, I think the Celeron D would be the better buy, considering the savings and that Netburst CPUs are all, at this point, shitty cpu's that you buy to hold you over until you can afford a conroe.
sorry i even asked lol. mines a p4 prescott. i only thought it had a chance to beat mine because it was dual core and 3.3. i didnt think about the cache size or fsb.
hmm, just curious why anyone would go with a celeron when you can get a sempron am2 that will do 3GHz :confused:
The Celeron D isn't dual core actually. That's easily confused since the Pentium D IS dual core. The Celeron D is only a single core.
Make up your mind. Are we gonna talk about what can be done with water cooling, or with air cooling?
Both of you, keep it civil. Everyone knows what Celerons are good for (low performance, even lower budget), so there's no use you two making a big stink out of who can hold out longer. Neither one of you will end up convincing the other one who's right, and everyone who's actually interested in this [H]Deal now has to read through all your filler and name-calling.
Can we conclude this sandbox fight?
You're the one who posted a link to an article showing a celeron 356 hitting 5ghz on air.
and the 805 was 3.9 Ghz on air, too.
And the 805 was KICKING THE SHIT out of the celeron.
Did someone make you a mod and I missed it?
I don't have to be a mod to get annoyed at childish bickering.
Well you might need a little common sense that's been missing from some of the posts. :)
I don't see replacing even a Prescot with a Celeron as making sense though, if you are really wanting an upgrade there just wait on the next C2Duo price drop and do it right IMO. The Cedar Mill Cellies are no 300A but they are nice for cheap system builds though, I wonder how far they will drop before Intel completely switches to their newer chips. Celeries with Netburst really do fill the low end well, a lot of people selling and buying the cheap stuff don't see much past the initial GHz rating on a cpu so I'm thinking that alone could result in a longer life for Netburst.
I wouldnt replace a perfectly good p4 with a celeron, ever. I was just stating that if I had to choose between the two, I'd just grab the celeron and save some cash, since the difference isn't that profound once you overclock the piss out of the celeron.
