cageymaru
- Apr 10, 2003
I don't own one so good luck! Seems that others think these are great as PC monitors. I left a link to the RTINGS review at the bottom of the page. There is a 75" version but it was only $300 off.
TCL 65R617 65-Inch 4K Ultra HD Roku Smart LED TV (2018 Model) is $719 at Amazon.
https://www.amazon.com/dp/B079NJMFL8/
TCL 55R617 55-Inch 4K Ultra HD Roku Smart LED TV (2018 Model) is $528 at Amazon.
https://www.amazon.com/TCL-55R617-55-Inch-Ultra-Smart/dp/B079N9HDNQ/?th=1
According to Reddit, Best Buy has a cheaper version of the same TV for $699 but the remote requires you to aim it at the TV unlike the Amazon version.
Best Buy 65" version is $699.
https://www.bestbuy.com/site/tcl-65...d-tv-with-hdr-roku-tv/6204551.p?skuId=6204551
Best Buy 55" version is $499.
https://www.bestbuy.com/site/tcl-55...d-tv-with-hdr-roku-tv/6204548.p?skuId=6204548
RTINGS review.
https://www.rtings.com/tv/reviews/tcl/6-series-r617-2018
The TCL 6 Series has excellent low input lag, as long as Game mode is enabled. With Game mode disabled, input lag is extremely high. 1080p and 4k input lag is very similar. The TV is a 60Hz panel, as such 120Hz input is not supported.
For use as a PC monitor, the TV automatically detects when it is connected to a PC. If it doesn't automatically detect it, changing the input label to Computer will enable PC Mode. For the lowest input lag in PC mode, Game mode must also be enabled.
The TCL 6 Series doesn't support any of the Variable Refresh Rate technologies like AMD Freesync. We tested on a PC with an AMD Radeon RX 580.
RTINGS review.
