can anyone help? when i press ctrl alt delete my a message comes up saying its disabled ive tried a few other things like running task editor also that is disabled my computor is running programs on start up can anyone help
First, use the programs in my signature to check for spyware/adware. Make sure to update them before running the scans.
Are you on a public computer, or is this yours? You could go into GPedit (if you are logged in with admin rights), and give it back if it was disabled.
Start -> Run -> gpedit.msc
User Config -> Administrative Templates -> System -> Ctrl+Alt+Del options
On the right side you'll see some options. They should all be set to "Not Configured" or "Enabled".
Don't mess around in there too much it has all the security for your PC in there .
im running xp and its my comuter i tried gpedit.msc and windows could not find it i have ran adware and spyware and detected none my computers runing as slow as a week in the jail any more sugestions?
A service pack is a Package of updates/fixes that microsoft issues periodically.. They issue updates once a month - unless something extraordinary happens and then they'll release a fix immediately....A service pack rolls all these updates into 1 nice package... currently they are up to service pack 2...If you've never run windows update then you seriously need to ASAP..
Click this link and download and install EVERYTHING under critical updates.
