System Upgrade Advice
ibskiing
Need a motherboard recommendation on upgrading my kids computer as cheaply as possible. The computer is a 10 year old Dell PII 400, upgraded to a Celeron 1.4 PIII w/ I Will slotkit, max ram 384. I'll keep the CD RW, DVD drives, floopy, zip drive, and 40 gig harddrive for now. But I figured I'd need a new case, MB, and etc. My son does love Age of Empires III, which is pretty graphic intensive. The Dell struggles, so he mostly plays on my computer.
Here is what I'm looking at:
ATOP X-Blade case w/ 450 PS $62.50
http://www.newegg.com/Product/Product.asp?Item=N82E16811105115
ASUS A8N-VM CSM nVidia Geforce 6150 Chipset (onboard video) $78.99
http://www.newegg.com/Product/Product.asp?Item=N82E16813131570
AMD Athlon 63 3000 Venice $145.00
http://www.newegg.com/Product/Product.asp?Item=N82E16819103537
Sapphire Radeon X850XT $154 (after rebate)
http://www.newegg.com/Product/Product.asp?Item=N82E16814102688
1 GB Crucial 3200 DDR (2 512mb) $76.00
Total price $516.50.
Questions:
1) Are there better budget MB, since I'll will not need Onboard video?
Main priority is stablility, upgradibility, & not planning to overclock. I've always heard ASUS makes the most stable boards, is the still the case? I've heard Gigabyte & DFI are good, but haven't heard much about the other companies.
2) Anyone know if the Power Supply with the X-Blade Case is OK?
3) If not, again with budget in mind what PS would you recommend for this set -up?
Mother board is great if you add more memory you may be able to get by with the onboaard grapics for Age of Empires.
I recommend you getting a new hard drive also as you are using a hard drive from the old system your upgrade will be almost worthless using the old slow hard drive. You can get the cpu cheaper and if you go on ebay or on www.pricewatch.com you can get the opteron 170 or 165 as these are 939pin and they overclock alot better you can get a large performance boost and the price of the opterons should be cheaper. let me know what you think
I'd try a different board rather than that one since you don't seem to interested in the 6150 chipset features (which are driving up the price). Maybe the Biostar T-Force instead in mATX or a DFI Ultra Infinity in regular ATX.
Nice pickup on that video card...that's a steal.
With a Venice like that, I'd OC it a little bit. You can probably do an extra 400mhz to get it to 3500+ levels with stock cooling and a decent board. The Biostar is good for that.
I'd probably get a different PSU, but that's just me.
You might run into a problem running a system like that with a generic PSU thats bundles with a case......probably no cheap way out......Remember a computer is only as fast as its slowest piece.....and using components from the old system, the slow pieces will be plentiful.
I recently wanted to build a cheapy but good system.
The PSU in the x-blade case will probably do you fine. My bro in law uses that case with a pretty loaded up system and it seems to hold up just fine, and has done so for about a year.
Here's what I'd suggest:
Mobo: ASRock 939dual SATA2 (ASRock is a value line of ASUS)
CPU: AXP 3000+ Venice
RAM: some sort of name brand PC3200 will do unless you overclock like mad, at least 512MB
Video card: ATi Radeon GT02 X800, unlocks and overclocks to past X850 XT PE speeds
HDD: Definately a SATA drive. I prefer Seagate myself
I have a comparable system and it does around 7k in 3dmark05, and the ASRock board is probably alot more flexible and nicer than the other cheapy boards out there. My system is overclocked to 2.5GHz for reference.
Thanks for the advice. After looking at some prices I probably will add a new harddrive. MWave has a refurbished Seagate SATA 160GB for $65 and I just saw that Newegg has a 250gb Seagate SATA for $95. I didn't realize how cheap harddrives had gotten. It was just a few years you had to pay over $200 for decent harddrive space.
As far as the other components I'm adding, the DVD is 16x and the CDRW is 52x, 24x, 8x, so they are still fairly up-to-date.
Regarding the Motherboards, I had originally planned to go with OnBoard video, but several people at another site convinced me to get a Video Card. Also, I had just read that ASRock is ASUS attempt to garner the lower end market. So far everything I've read about ASRock has been pretty good. I haven't read much about BioStar, are they a fairly new? And, do they make pretty stable boards? Before I built my first computer I had read the Abit were high on performance but tended to be flakey, so I steared away from them. I went with ASUS and have not had any problems.
Hi,
Not to really rock the boat but did you happen to price out another Dell or HP PC? I was going to build a PC for my aunt cause her 366 was not cutting for her, and it came out the price for a build verus "pre built" was alot different. We went onto Dell, got a descent set up, with a P4 2.8, with gig of RAM, 17 Flat Panel, Wireless K/M combo, descent sound, 4and 1 printer, with XP Pro for around 800 bucks! Mind you the Flat panel was a $150 upgrade, the RAM was double it up for free upgrade, XP PRo was 60 bucks. The K/M combo was 40, the speakers around 60. So the PC was really was only like around 500-600.
However, if you are like me, and feel the need to upgrade, as needed or what not. I would go with what the guys above are saying. I hread great things about the Asrock 939 board. I know a few budget gamers who use that board with alot of sucess. From the reviews I read on the board, the chipset is pretty powerful, and the Video side of things is really smooth. I was thinking about one of those boards for another system I was going to build. However, We are looking about a few big changes in the next few months to a year down the road.
Later,
Alan
shaggy77,
You didn't rock the boat at all. I did look pretty hard at Dell, Gateway, Alienware, Falcon and a few other onsite places. In pricing out similar set-ups online, I'm saving on average about $200. Of course most of these also come with more than I'm adding. I also visited BestBuy and Circuit City, about the only two places in my town to buy pre-builts. The e-machines, HP and Compacs are pretty tempting when look at the prices after rebate. In the old days you could definitely build a computer cheaper than buying one, but that doesn't seem to be the case so much anymore. However, with the E-machines and HP, you have no idea what vendor products they are using (i.e. Maxtar vs. Seagate or MSI vs. ASUS).
In the end, the proprietary nature of Dell and other manufactures PS and cases made me decide to build. And, like you said, you just have much more ability to upgrade if you build it yourself.
Xeon,
Thanks for the review on the ATOP PS. I think I will stick with the stock PS for now and go with an ASRock. However, I was looking at getting the NF4G vs. the Dual939, since the NF4G also support Dual Core 64X2.
Well they both support dual core. I'm not positive to why it doesn't say so, however, it does. I ran one myself just to see what the hype was all about, and many people here do run dual cores on them. I don't know much about the other board to say which would be better, but the one I'm running is as stable and quick as any high end ASUS board minus a few features.
Xeon,
You are correct, I went to the ASRock website and also read a review from Tweak Town and the 939 Dual does support the 64X2. Along with potential support for AMD's next chipset.
Question: The specs state the Board has support for 4 USB ports in the Rear and 4 via an expansion slot. Do you know if the four available via an expansion slot can be use for USB ports on the Front of the Case? Not that big of a deal, but the X-Blade has two USB hook-ups in the front of the case, so it would be nice.
