Alrighty guys...I'm stumped with this and I need some input. Here goes...
First off here are the system specs for the system:
Ok so a friend of mine called me and said that her computer went kaput...she said she was playing City of Heroes and then it just turned off. She also told me that she was hearing a funny noise coming from it and since I wasn't able to go down and see it...what she described sounded maybe like a bad power supply.
So when I went to do a quick inspection, the PSU would turn on fine. Now I should also note that she is on her SECOND Geforce 6800 (AGP) b/c her first one crapped out on her (it was an XFX-brand card btw.) It was replaced with a BIOSTAR Geforce 6800XT card which seemed to work fine until her machine crapped out.
However the strange part is that when I unplugged the 4-pin molex power adapter to it, the system would power up fine but I would have no video. I thought it was the motherboard so I had her purchase a new board (a BIOSTAR P4M80-M4) thinking that would be the source...but it wasn't. When I powered everything back up to start installing Windows, I had the same problem...but when I took the card out and used the on-board video it worked fine. When I put the video card back in but did NOT use the 4-pin molex power power adapter, the machine booted up but again no video.
So can anyone give me some ideas...I'm stumped on this one. I know the HDD is fine b/c I was able to back up here data and use Hiren's BootCD to check it.
- Pentium 4 2.4Ghz (478) FSB800
- 1GB DDR RAM (512 x 2)
- WD SATA 120GB HDD
- (Originally) Giga-byte GA-8IPE1000 Pro-G
- (Replacement) Biostar P4M80-M4
- Thermaltake Xaser III Silent Pure Power 480W PSU
- DVD-Burner (IDE)
- DVD-ROM (IDE)
