Ill give my pc specs so you can see where Im coming from.
Asus A8n-e (latest bios and drivers)
SD 3700+ (939)
2x 512mb ddr 400 (corsair vs)
ati x800xl
power color theater 550 pro tv card
antec true power 2 550w
chaintec av-710 sound card
nec 3520 dvd burner
both the chipset and cpu have better than stock cooling both with low temps
3 Hard drive
80gb sata (has the OS on it)
160gb Ide (has games and this is where my tv card records too)
200gb Ide (Movies, and random files, back up stuff)
So now to my problem, I think my pc is having some sort of hard drive problem, like when I start MCE and try to watch tv it takes forever to load or if I watch my recordings it can take forever. When I play WoW, my addons slow down my system lots, if I remove them wow runs fine. Auctioneer records all the auctions and stores there info, which means lots of harddrive accessing, this addon can really lag wow up. Also my board will not overclock past 230fsb (I have tried everything to fix this, I mean everything but this is not the problem im here for) which makes me thing that my board has some kind of problem and is slowing things down. Its been perfectly stable, but trying to play just mp3's it seems like it takes longer for wmp to open than it should, along with outlook and other applications. Running wow and firefox and WMP can be a pain, I know I dont have duel core processor but it shouldnt lag to bad running these 3 but sometimes it does
Is there a program I can use to see if there is something up with how my mobo accesses the hard drives?
SD 3700+ (939)
ati x800xl
nec 3520 dvd burner
3 Hard drive
