Greetings all....first time poster here
Having some trouble with a new build, and was hoping for some insight.
I'm using an Epox 9NPA+ Ultra
3000+ Venice
1gig OCZ 2.5-3-3-6
Thermaltake 420W PSU.
I have had several BSODs after boot, resulting in me just reloading XP. That seemed to help for awhile. I was getting the "FF" code on the LED, which I'm thinking isn't grand. I flashed the BIOS using the webtool and cleared the CMOS via the jumper. I don't seem to be getting the "FF" code now, but it changes intermittently.
Last night, and out of nowhere, the system stalled at the WIndows XP splash screen...looked like it would load but never did. I did a soft reboot and now the system is hung at the Epox splash screen.
I'm no diagnostician, but I'm suspecting either a bumpy XP install, or a bad motherboard.
Any suggestions? Let me know if there is additional info required.
Thanks much!
3000+ Venice
1gig OCZ 2.5-3-3-6
Thanks much!
