System died 2 days ago...
LunaticPuma
...so I need to build a new one. I wasn't really planning on building anything for another 6 months or so, but I need a computer.
Old set-up:
Athlon 2500+
6800GT
1 gig PC2700
Looking to build:
C2D E6600
G.Skill DDR2 800 (2GB)
Seagate 160 GB 7200.10 (for primary drive, will add second larger drive later since I don't need much space)
Seasonic 550W PSU
I'm stuck at MOBO, and video card. I don't need a super high end video card since I'd probably only play HL2, Doom 3, Warhammer 40K, and probably Spore when it comes out. Since Spore is the only new game I really would like to play, how high up the food chain should I go right now? I know DX10 cards are coming down in price soon, but I need something now. I think either an Nvidia 7 series or ATI X19## would be a good choice.
I don't plan on overclocking much, but I would like to be able to upgrade at least to a faster chip once and maybe faster memory at some point. What's a good MOBO for that?
I have no strict budget, but I'm looking to stay roughly $1000 give or take. Mail-in rebates don't bother me too much either.
Thanks for all of the help!
I say grab the 8600GTS when it comes out on April 17th. It'll be a bit more future-proof.
As for mobo, I recommend the Gigabyte GA-965P-DS3. It's $123 at newegg.com and it's one of the best mobo out there. And it can accept Quad-core CPUs should you ever want to get one.
If it's less that $100, would it be better to get an 8800GT (or whatever the lowend 8800 is) over the 8600?
Do you mean if the difference between the 8800GTS 320MB and 8600GTS is $100, should you get 8800GTS?
If thats your question, then I say get the 8800GTS. It's about $280 now at newegg and several sources have reported that 8600GTS may cost anywhere from $200 to $229.
Yes, that was my question. Many thanks Danny. I will go for that Gigabyte board so I can be ready for quad core. I'm going for the rev 1.3 board which seems new (only 1 review) at newegg. Any reason for me not to get the rev 1.3 board?
Thats the old version of the DS3. Don't go with that one. Go with the other DS3 choice. The new version is a bit more stable and it's a better overclocker.
