I have an odd issue with my system cold booting after being off for a while.
When I turn it on, it will attempt to start up, fail, try again, fail, set stock safe settings, and then boot fine. (This is a p35-ds3r, so it resets itself upon failure to boot after 2 tries.) I can then go directly back into the bios and change all the settings back to how they were before it reset itself, exit bios + reboot and it boots up at my OC'd settings like a charm.
The system is overclocked, and from the description it sounds like it just can't handle the OC right? But the weird thing is that its 11+ hours stable in orthos, (I terminated the test before failure) and the temps as reported by TAT, Speedfan, and Bios are fine. It just recently developed this problem too, it did not used to be like this. I was hoping some of you might have a few ideas as to why this is.
System specs:
Board: GA-P35-DS3R (Updated to F6 bios)
CPU: e6420 w/TR-U120x
RAM: 2gb Ballistix 1066
Video: 7950GT 512mb
PSU: Corsair HX620
Case: Antec 900
Other stuff:
-320gb Sata drive
-37gb 15k rpm SCSI on an Adaptec 29160
-2x Sata optical drives
OC:
-e6420 @ 8x437fsb = ~3.5ghz. @ 1.47v (bios)
-Mem @ 4-4-4-12, 1:1. @ 2.2v (bios)
-"Performance Enhance" setting on "Turbo" in Bios. (memset performance level 7)
-Video @ stock
-Everything else @ stock.
I was originally thinking a power issue during bootup, but I dont really want to believe it because the HX620 should be up to the task. It fails initial cold boot after about 5-8 seconds, not quite enough time for my CRT to warm up and show me the boot screens.
Any ideas?
System specs:
Video: 7950GT 512mb
PSU: Corsair HX620
Case: Antec 900
Other stuff:
-320gb Sata drive
OC:
-Video @ stock
Any ideas?
