DeathPrincess
- May 15, 2010
Having an annoying problem with these.
I have a friend who plays a game which likes to use the documents folder for pretty much everything. Caches of items, 3 copies of the cache. Piles of junk that serves no purpose. As it;s their faviote game the C:/ drive (an SSD) is getting rather full with 11gb+ of these files.
So immediately I thought ill do a symbolic link
and entered the usual;
mklink /H Drive:\Folder 3 Drive:\Folder 3. But this just gives syntax errors when I try it. Testing it without the spaces makes it work fine...the test folders work exactly as they are supposed to. I've never done symbolic links on a folder with spaces in the title, and the folder cant be renamed. Is this normal or is there a workaround, or am I just messing up as per usual
