alright heres the deal i just fried my 3.4e so instead of replacing an aging socket 478 chip im thinking of moving to a socket 939 amd system. Im going to sell my BFG 6800gt OC agp and buy either the pci-e version or get an x800xl. I figured i might as well move to 64bit and pci-e so ill be ready for the next gen video cards and for longhorn (or xp 64bit). So heres my question i havent built an amd system since my old k6-II system (400mhz of awesomness) so what would be the absolute best mobo for overclocking keep in mind i will not be using sli or amr so 2 pci-e slots will not be used. Also i dont wont to spend more than $300 on the cpu
so what would you suggest? By the way i use ebay all the time so if you can recommend a product that would be easily found on ebay go ahead and recommend it
im thinking of a a64 3200+ but im not sure wich cores oc better (arent there like different 3 cores for that chip) anyway let me know what you guys think
