Switching to a Micro-ATX mobo?
I'm thinking about swapping over to a Micro-ATX motherboard so I can ditch my ugly case for a much smaller, quieter one. I'm not sure, however, if all of my current components will fit into one, seeing as I've never tried this before. What kind of board should I look into, given the components in my sig? I don't do any overclocking, so there aren't any big after-market fans or heatsinks. I mostly use the computer for gaming, so I'd look room to upgrade eventually, but I don't have the cash to keep all my stuff current or top-of-the-line.
Also, this was the case I was considering, if it matters: http://www.newegg.com/Product/Product.aspx?Item=N82E16811292003
Your stuff should fit, the 7800GT wasnt to big of a card. For S939, the Biostar Tforce 6100-939 was hands down the best matx board. Awesome board to deal with and never had any sort of issues when I had mine. It was a well liked board and has a ton of information on it floating around. If you do end up deciding to overclock, it is the best matx board for it. Shouldnt be to hard to find one for under $60, Ive seen a few used/open box as low as $40.
If the US is anything like the UK then finding a good 939 mATX new will be virtually impossible.
MSI's K8NGM2-FID was also a very good mobo.
I'd say that was the 2nd best. The Epox , 6100 I believe, one, ugly, was hands down the best one. It is tough to get but well worth it. Had less of the issues just wasn't as widely available. I had both BTW. The Biostar is good just not the best.
If I recall the Epox had a tad better layout as well.
However if you aren't OCing then almost any MATX 939 board should do.
Bear with me here for one last question, but just to be sure before I order, all my standard components are going to fit on this board and in the case I linked, right? I'm not going to need any special power cables or anything like that?
Thanks a lot for the advice, I really appreciate it.
All your standard cables should work fine.
I made the switch to micro ATX recently too. There really isn't any general difference in full size and micro ATX other than the mATX boards have a smaller footprint and less expansion slots. A lot of the mATX boards are not fully featured, but there are some very nice boards made that have everything most people would need. I have an Abit NF-M2 Nview mATX motherboard and am very happy with it. But it's socket AM2 and won't work with your processor. I have an mATX Asus A8N-VM CSM in another computer in the house and it is socket 939 and works very well. It would be a good choice if you could find one, although I think they might be discontinued.
All your stuff should fit in that Spec Research case. btw we have 2 of those cases at work so I have some experience with them. FYI the airflow in that case is very poor, and ***THIS CASE DOES NOT COME WITH ANY CASE FANS!!*** So you absolutely have to order at least a couple 80mm fans unless you already have some 80mm fans laying around. The case has 3 different places to put 80mm fans on the back, and although there are places to put 80mm fans in front they would be worthless because there is no place for the case to draw in air. All the fan templates on the case are 80mm. The problem with the case is there is basically no way for air to enter the case other than the cracks around optical drive doors and case edges and stuff. You can leave one of the 80mm fan locations open and then the case will draw in air from the open fan location in the back, and vent it out the other fans. This is not a real great arrangement though because air will only flow in area near the rear of the case. This case seems very much geared towards HTPC use. Also the case is pretty big, you'll be surprised at how large and heavy it is and it *does not* come with a power supply. It does accept a standard ATX power supply so you can pull the PSU from the old case. The floppy/card reader door and the audio/USB ports doors are bad about sticking on this case. The optical drive doors on this case will stick with some optical drives depending on if they tray of the drive has a lower "lip".
I am kind of bashing it due to several design flaws, but otherwise the case is well made and the entire front is thick aluminum. I'm intriqued by the thick aluminum construction and the folding top on this case (it's very easy to work on), but it is really not a very good choice for a gaming case due to the poor airflow and other little issues. The X-Qpack 1 or 2, the Microfly, or the Thermaltake Lanbox might be better choices for mATX gaming cases. Good luck!
Thanks for the advice, hunter! Back to the biostar, will the AM2 socket version fit a s939 processor? I haven't been keeping up with hardware, recently, so I'm not sure. If it fits both socket types, would it be better to get that one? Are AM2 processors more advanced than s939 ones?
I forgot to mention about that Spec Research case, there is a blue LED trim ring around the power button that is extremely bright. It is so bright it might bother someone who had the case near their monitor. (Although you can unplug the LED) It still baffles me that there are literally no air vents of any kind on the case, I just don't understand why they would design it like that. They don't tell you anything about the fans/fan sizes or LED online and I bet some people were irritated when they got this case.
Socket AM2 processors will not fit in a socket 939 motherboard and vice versa ... the pinout on the processor is slightly different between the two. Socket 939 processors usually have a little more cache (depending on model/clockspeed), and socket AM2 motherboards use DDR2 memory. There really isn't a whole lot of difference between the two sockets except that 939 is technically "obsolete" and it's harder to find S939 processors these days. There is virtually no difference in speed between the two ... just socket AM2 is newer and "current" and there may be a slight performance increase due to the DDR2 memory. Also since socket 939 processors aren't being made any more you can't get them in today's fastest clockspeeds.
hmm, ok, that's good to know. I'm thinking about maybe getting the AM2 version of the mobo and getting the 4200+ AM2 processor, since it's only 90 bucks and a very solid upgrade from my sad little 3000+.
