Switching Motherboards
O-P-M
Right now I have a Chaintech VNF4 Ultra motherboard and I likeit and its rock solid but I wanna go SLI. What would you guys recommend? Also, what would I do when doing this? Just switch them out and everything will be ok? Or do I need to do a bunch of other stuff?
**EDIT** I'm really torn between maybe just keeping my chaintech and getting a new case. LIke this one. http://www.newegg.com/Product/Product.asp?Item=N82E16811129154 or a Lian Li V1000. Any suggestions?
My first thoughts are the Dfi board with the 2 pci-e slots but its not the Sli one. Or the neo4 platinum.
Re-install windows after you switch...otherwise you'll end up with a big headache.
You might not have to reinstall Windows. Theoretically you are moving to another chipset that uses the exact same drivers. If you were going from an NF2/NF3 to an NF4 board, I'd say that might be true.
I had a chaintech like that and I liked it. The only reason I got rid of it was because my friend wanted me to build him a computer, so I gave him my old one. I have an Abit AN8-SLI now, and it's a good board too. If you're not going to use SLI, just stick with the Chaintech and get the P180. It's a nice case. I thought about getting one myself until I got a super deal on a Lian-Li PC-61.
i would only do this if you really-really have to have SLI -
otherwise just get one 7800gt and stick with the system you got----if you have to have sli there are lots of them out there . :cool:
only have experience with the ASUS A8N-SLI Premium but i give it two thumbs way up. if SLI is your goal i wouldnt look any where else, there is the most room between the PCIe slots than on other boards, and the SLI is autoconfig. not to mention with the premium it is one less fan to listen to.
I don't think I will, I think my 7800GTX will be fine without a friend. That antec case is to sexy to pass up.
