Switching motherboard 780i
r0k
If you have a stock dell pc right now the one thing that comes to mind is the power supply. I'm certainly no expert on dell stuff as I build my own and have for the past 15 years. From what I recall about a few of them I've seen in the past some had proprietary power supplies which were not friendly to standard parts. Someone who is more familiar with dell hardware may be able to shed more light on that than I.
Looks like you have an Intel board. Not sure if it's a Dell rebrand or if they just used the Intel board outright. See the board here; http://www.newegg.com/product/product.aspx?Item=N82E16813121035
It's a 965 chipset, there is not too much difference between that and the 780i except for things such as SLI ready, PCI-Express 2.0, etc, etc...
At any rate, you're probably going to need to change your power supply. As mentioned by the poster above it may be proprietary or at any rate I doubt it'd work with an SLI setup.
But aside from that, everything else should work fine. I once did a Compaq rebuild and the only items I didn't reuse was the motherboard, case and power supply. The rest should be pretty much industry standard.
Hope that helps,
- Joey
It should all work, but you might need to do a Windows reinstall or something like that. Might not have to...might just be a reactivation thing, but if it's an OEM copy, they don't like the reactivation.
When you're changing the heart of your system, I always suggest an OS reinstall. Also need to make sure your OS is not locked to that particular Dell system, otherwise you might have to buy a new copy.
- Joey
If you aren't going to upgrade to SLI I'd avoid the 780i SLI.
