Switch to PCI-E w/ current CPU - advice? (Intel-based)
Xathagorra
I want to switch over to PCI-E but want to keep the CPU I'm currently using, because I am a hardcore gamer and cant afford a new high-end CPU at the moment, and mine does just fine.
So just switching the mobo (PSU as well?) then to a PCI-E card (which will be expensive enough) will be easier and cheaper than also throwing in another CPU (and I want to stay Intel-based for now).
Can this be done with the CPU I'm using? If so, can someone help me find a compatable mobo for my CPU (which everything is based around)?
I'd really appreciate the help.
I'm running a P4 Pentium 3.2GHz CPU, 800 FSB, 512 L2 Cache, 1.55V, Socket 478.
Oh, I'm also running 1GB Twin Corsair XMS 184-pin RAM which I'd like to keep.
So I need a compatable PCI-E mobo, PSU etc. though a CPU is the one thing I've never installed in a system (though I am mechanically-inclined, to say the least; ex-automotive rebuilding, machinist etc.) so I might need some suggestions there as well.
It's time to move into the next gen of PC gaming, even though my current system is really solid, so whatever really in-depth info you gurus can give me would be greatly appreciated.
Cheers.
socket 478 boards with pci-e are hard to come by (but they do exist)
one problem is that you need a board that'll run reg ddr too (intel 915/ati express 200 chipsets)
i would suggest gettin a S775 system and sell what you have... the 805 is selling for under $130 on newegg... i would think you could sell your current cpu for that amount if not a little more
You're right, and I've decided to make the move.
Perhaps you could guide me further from here then?
Was thinking of going with the Intel Pentium 4, 3.4 GHz 650 Prescott 800MHz FSB 2MB L2 Cache LGA 775 CPU which is LGA 775.
The price is not that bad at all on Newegg, especially for a CPU that seems that powerful (considering I'm running a 3.2 now which is really solid).
What mobo would you suggest?
Preferably one which would allow me to keep the RAM I'm running?
Since the CPU is still Intel, could I keep the same PSU (520W - made for Intel P4s) I'm using?
If so, I could snag all of this tonight, and all I'd have to worry about would be the new card, and I'd be set to go.
Thoughts?
Thanks & Cheers!
That prescott running at 3.4Ghz will be similar in performance to the Northwood at 3.2Ghz. Are you OCing?
I'd look for a board that is Conroe ready since the current lineup of Intel based CPU's leave a lot to be desired compared to their AMD counterparts. Just my $0.02.
