Is there a way to switch between the headphone and computer speakers without having to plug/unplug the headphone every time? Basically, I want to be able to leave the headphone plugged in and to switch back to speakers without having to unplug it.
Doesn't your sound card have both a line out and a headphone jack?
If you have the speakers connected to "Front Speakers" or the Green connector on the back of the PC, the headphones plugged into the front panel connector and the Realtek driver/software installed, you should be able to easily do this in the Windows "Sound" control panel.
I do this but my speakers are connected to my M-Audio soundcard and my headphones to my onboard Realtek chip.
I've got one of these Plantronics "PC headset switch" devices. Have it mounted on the underside of my desk and it works perfectly. Very simple device and unfortunately discontinued. You can find em on Amazon and ebay sometimes though...
http://www.plantronics.com/north_america/en_US/products/cat640035/cat3600586/prod3090125
http://www.payphoneoutlet.com/product_info.php?products_id=15492
i have the logitech g110, it has audio ports on the back of it. you can use that too.
i know this thread is a bit old, but i'm currently searching for a way to switch realtek outputs with a script/program.
right now i leave headphone+speakers plugged in, then go into the realtek cp and remap them to switch... wonder if there's a way to do that automatically without having to go into the cp...
