Indeed.
I'm hearing an echo.
-10c is much colder then just "sub-freezing temps". -10c is 14f.
Cars without anti-freeze crack blocks and radiators at these temps.
I'm sure most shipments get nowhere near that cold, H110i GT or others.
So why recall all H110I GTs' from retailers?
I don't know about cargo holds not being heated, but I do know that normal luggage and shipments do not freeze.Zarathustra[H];1041462348 said:Well, for one, if air freight is used, the cargo holds of planes are not heated and it gets very cold at high altitudes.
-10c is only 10c below freezing. Not a big deal.
I have never heard of a car without antifreeze in it...
You are correct -10c is 10c below freeziong, or 14 degrees Fahrenheit .. and in many parts of the world that is a big deal. Here in the UK -10c is a big deal .. and is southern California, and Florida, and Texas.
But we digress. If few have frozen and a very few of those leaked .. which seems to be the only problem, why recall them all? In their own words Corsair says they have found no problems with any they have tested.
As for cars without antifreeze, try Florida, southern California, etc.
http://forums.overclockers.co.uk/showpost.php?p=27649508&postcount=2As a precautionary measure, Corsair has recalled the H110i GT from our resellers for screening. Here’s some information about what this means to you.
1. We discovered that when some units are exposed to extremely cold, sub-freezing temperatures during shipment, they can leak small amounts of coolant.
2. This problem can be immediately identified when the box is opened as some users noticed small drops of coolant in the plastic bag surrounding the unit.
3. If there has been no coolant leaked in the package, the unit should operate normally and with no problems.
Though we have seen no failures of units during operation, and have tested units in a wide variety of conditions to verify they have not leaked once installed, we understand that this can be disconcerting. If you have purchased this product and have a concern, please contact your reseller or Corsair directly to return the product. We will likely not have replacement units available for six weeks, as the entire recall, screening, and remanufacturing process takes significant shipping time.
Thank you for purchasing Corsair, and we apologize for any inconvenience this may have caused.
Hi Guys
I have had information from Corsair this morning that they are issuing a product recall on their new Hydro H110i GT CPU Cooler.
The reason for the recall is for something that is a fairly unlikely scenario, if the unit goes below -10'C then it will leak.
All of our stock has been removed from sale, I would urge any customer who has purchased these products to contact our returns team so that we can assist you.
Any questions, just post in here and I will do my best to help.
Rich
UPDATE FROM CORSAIR:
The H110i GT is only a channel recall any units sold to end-user that are fine out of the box wont be affected
Cool will look into that. Also anyone know how to remove the 5.25 bay inside the 450D case?
I threw a gelid silent 14 PWM fan on the bottom side of mine, but also switch some other fans around at the same time, dropped 5 degrees, but ive expanded the loop and have a 290X in there and a UT60 140mm rad as well. It helps for sure, but I only imagine 1-2 degrees, its a fairly low FPI rad, not very restrictive. I just had the fan so I threw it in.
How does the new Corsair H110i GT fair up against Swiftech H240-X?
Any reviews with both in the test?
[CoF] ATOMIC;1041388015 said:Can anyone confirm that the Swiftech H240-X cannot be mounted vertically like I did here with the H100i?
Weird, that doesn't look like air in the picture.
If its fairly new there shouldn't really be much if any air in it. If you have burned off some of the liquid there could be space filling in where the water was.
I've had mine running since November and cannot see anything like that in mine. Granted I don't have an angle that is easy to see at it like that but I wiggled my case and nothing moved.
Update:
Just confirmed my pump died on my setup. Who do I need to contact to get a replacement setup?
What else does it look like if not air? I've had mine for a couple of months. I remember it was really loud when I first got it and I had to add dish soap to quiet it down - perhaps that bubble is the culprit? I wonder if my pump would be quieter if it was gone altogether...
Honestly not sure, just in that image it looks like a part of the reservoir. If you move the case around and it moves around then yeah its most likely air.
Mine has been very quiet and operating without issue since November, all I did was install it and be amazed at how easy it was vs the last time I went water. I wonder if something in yours is defective generating the noise and potential air.
Swiftech H240-X mounted vertically inside big dual-width case Lian Li PC-D8000
Yes, no problems. The next step is to change the Swiftech CPU cooler to the Liquid Extasy full cover water block.Sick. Is it performing as expected?
Ooo...that looks nice. Any idea how much better that would perform? I'm definitely looking to upgrade my H-240X down the line, wasn't sure if I should add additional radiators or just get a better waterblock.
This is interesting questions but nobody has answer yet since the waterblock is brand new, I am one of the firsts who ordered it. Production is just starting and is made to order, first coolers will only be available in ~2 weeks time. Regarding the Swiftech waterblock there were some reports that its performance is a bit down probably due a contact problem.
Curious if you will get any better temps than the block it has.. it's supposed to be a good block to begin with.
Zarathustra[H];1041541462 said:See, that is what I heard two, but then I read some comparative reviews and it didn't fare all that well...
Swapping blocks for a couple C difference seems a little extreme.
Zarathustra[H];1041541525 said:That being said, there was a comment to the test that their results were atypical, and maybe the block wasn't seated properly.
I'm not sure.
I contacted Swiftech and they said it's normal to see a small amount of liquid evaporate after a few months of use. Mine's quiet, but it's all relative - it was just a worry that perhaps my unit's pump was slightly louder than it should be, but odds are that all is normal. I only hear it if I have my Noctua fans turned all the way down, and never paying specific attention to a cooling pump before before I wasn't sure if it's something I should hear at all.
I'm still extremely satisfied with my unit. It's cooling just as well, if not better than when I received it. Honestly, it's one of my favorite purchases in the last year. Coming from the H80i - it's like a night and day difference.
The real excitement is when I'm upgrading from my i7 930 so I can see the benefit on newer CPU's.
Zarathustra[H];1041541525 said:A couple of C is HUGE. It can mean the difference between stability and crashing when overclocked.
Even a single degree is a big deal. I wouldn't swap a block over 0.1 or 0.2C but multiple degrees is enormous.
I'm not sure.
This is interesting question but nobody has answer yet since the waterblock is brand new, I am one of the firsts who ordered it. Production is just starting and is made to order, first coolers will only be available in ~2 weeks time. Regarding the Swiftech waterblock there were some reports that its performance is a bit down probably due a contact problem.
A single degree is NOT a big deal at all.. if you are that close to the edge of stability that is just bad news as ambient can change and then your 1 degree is lost. 1-2C difference is pointless for a daily used rig. If it was closer to 4-5C I could understand it being worth the change but 1-2C is nothing and by no means a "Big Deal".
