Swiftech Apogee vs. Storm
JOKER_JOKER
Within the next few days I'm going to be ordering my watercooling setup. But I'm still baffled as to what CPU block I should get. From Jab-Tech's site it looks like they are pretty much the same thing, as far as spec's go. But why is the Apogee like half the price of the Storm? Since I don't really know the significance of thermal resistence and pressure drop, can someone tell me which one I will get an overall better performance out of?
Also, could someone tell me which is the best anti-corrosive/non-conductive water additive is the best? I hear MCT-40 is the best water additive to get. Is this correct?
thermal resistance: lower is better.
difference in price: difference in quality, difference is complexity, difference in performance.
get the sorm if you can afford it. it is a better block in every way.
get the apogee if you need to get something cheaper, but open it up and go over the interior metal pins with a wire brush prior to using it. there are more than a few threads and reviews that you should look up to find out the reason why........
non-conductive water replacement and anti corrosion water additive are two different things. i use distilled water and car antifreeze myself.
I know they are two different things, but isn't the MCT-40 both a non-conductive and an anti-corrosive water additive? On the Danger Den description it says the MCT-40 is non-conductive, prevents algae growth, and prevents galvanic corrosion. So, doesn't it do it all basically?
I'm planning to use distilled water and MCT-40.
MCT 40 is a water replacement. if you use MCT 40, you need enough to totally fill your loop and you don't use any water at all.
that's assuming that I am reading the page correctly......i suppose that i could be wrong, but i don't think that i am.
Your correct. MCT 40 is not an additive, its a replacement. Adding distilled water to it would make it loose its non-conductiveness.
Touche. So, I would ONLY add MCT-40 to my loop and nothing else? I wouldn't have to add anything else to prevent algae growth or corrosion? And do you think a 32 oz. bottle would be enough to completely fill a loop containing a gpu block, cpu block, BIP III, and a fillport?
Depends on how much tubing along with parts, but no additives are needed for algae because algae only grows in H2O :D.
Oh yeah, 32oz is pleanty if your not using a res. I use Koolance refill kits in my look, a pouch is 23oz and I had a good fourth of a pouch left with my loop filled.
