Hello,
I think I am in the right forum.
I am looking to install between 4 to 6 cameras on the outside of my home. What brand do you guys recommend? I have been researching but the review are all over the place on these things.
I got a quote on the following, seems a bit steep, plus I want to buy them myself and I have an electrician that can install for much less than they are charging me.
Installation $596.00
4x LILIN LR7022E4
2 Megapixel 15 FPS - 1080P HD PoE Outdoor IP Bullet Camera 4mm Lens w/Built-In IR $1,196.00
1x LILIN NVR200L-4TB
LILIN 16-Channel, 200FPS Mid-Level NVR with 4TB Storage $979.00
1x LILIN ZLI-PMH-POE08130WT4
8-Port Fast Ethernet Switch with 4 PoE+ Ports and 4 LAN Ports $499.00
Security Camera System Total: $3,270.00
